A big twitter discussion on FH by Elon, Doug Ellison, and Scott Manley with lots of important details about FH:
Elon Musk on Twitter
Elon:
The performance numbers in this database are not accurate. In process of being fixed. Even if they were, a fully expendable Falcon Heavy, which far exceeds the performance of a Delta IV Heavy, is $150M, compared to over $400M for Delta IV Heavy.
When asked about improving the second stage:
Under consideration. We’ve already stretched the upper stage once. Easiest part of the rocket to change. Fairing 2, flying soon, also has a slightly larger diameter. Could make fairing much longer if need be & will if BFR takes longer than expected.
Both exhaust velocity (Isp) and mass ratio drive the rocket equation. Also thrust/mass matters a lot for Oberth effect. Delta upper stage Isp is good, but mass ratio and thrust are not.
Elon discusses FH expending the center core:
Side boosters landing on droneships & center expended is only ~10% performance penalty vs fully expended. Cost is only slightly higher than an expended F9, so around $95M.
Discussing comparative rockets cost when told a Delta IV Heavy is less than $400 million:
That was three years ago, before ULA cancelled all medium versions of Delta IV. Future missions have all Delta fixed costs piled on, so their cost is now $600M+ for missions contracted for launch after 2020. Nutty high.
When someone mentions Vulcan as competition:
Maybe that plan works out, but I will seriously eat my hat with a side of mustard if that rocket flies a national security spacecraft before 2023.
Tory Bruno commented:
Hey
@elonmusk , congrats again your heavy launch. Clarification: Delta IV Heavy goes for about $350M. That’s current and future, after the retirement of both Delta IV Medium and Delta II. She also brings unique capabilities, At least until we bring Vulcan on line.
Here you go:
