My M3 started vibrating at around 3k miles, and I replaced the OEM tires at around 8k miles due to feathering and inside tread wear, assuming that was the cause of the vibration. Unfortunately, the new tires didn't solve the vibration. I'm now at around 17k miles and the place I had the tires road force balanced at said "these are just not quiet tires" (Quatrac Pros). They also noted that the tires are cupped in the front.
I picked up a new set of OEM tires plus rims from a forum member, but I'm not sure if I should put them on at this point. I'm starting to think that perhaps there's an underlying suspension issue and that any tires I put on will be damaged. Either that, *or* I'm just ruining tires from my driving habits. I don't feel like I'm driving that aggressively, but I do appreciate a fast start and have done so fairly often when it feels safe.
While I expect that aggressive driving will cause the tires wear faster and thus require more frequent tire replacement, I don't have the experience to know if that implies uneven wear / cupping / feathering. I could really use the help of a "car whisperer", and would really like the vehicle to drive as smooth as it did in the beginning, whether I decide to take off fast sometimes or not.
For those of you who sometimes launch the car on "green" - have you all chewed through and destroyed your tires quickly?
