Firmware Upgrade Tracker on the touchscreen?
Discussion in 'Model S' started by Patrick W, Feb 27, 2017.
  1. Patrick W
    Patrick W Active Member
    SLC, UT
    I've tried several times over the past few days to get the Tesla Firmware Upgrade Tracker (Tesla Firmware Upgrade Tracker Web App) to display on my S's touchscreen. Failed every time.
    Anyone else try this and, if so, did it work?
  2. t3slaMS
    t3slaMS Member
    It may not work as expected as the touchscreen browser cannot handle the libraries that firmware upgrade tracker uses.
  3. croman
    croman Active Member
    Chicago, IL
    Maybe 8.1 will help.
  4. luckyj
    luckyj Member
    Northern Virginia, USA
    8.1 might help the page render, but the site really needs a mobile-friendly ("lite") version. The current page is doing things that don't work well on devices with limited computing power. Try pulling it up on your phone. It's quite slow.
  5. croman
    Chicago, IL
    Works pretty well for me. Displays the charts relatively quickly on my wifi. I have a Samsung Galaxy s5. Nothing new or fancy.
  6. luckyj
    luckyj Member
    I think the top part comes up pretty quickly, but all the tables below take some time. The delay is noticeable, even on well-powered desktops/laptops.
  7. HankLloydRight
    HankLloydRight No Roads
    Connecticut
  8. LastGas
    LastGas Member
    South Carolina
    It used to work on the touch screen, but started failing around the time the tracker site switched to https.
  9. HankLloydRight
    Connecticut
    How does it fail?
  10. HankLloydRight
    Connecticut
    Ok, I had to drive somewhere and tested this, and it does not work at all. I'm not sure exactly why. I think the browser has problems with HTTP code 302. I made one change to test.
    I'm away from my car for a while, if anyone is, please try again: https://ev-fw.com thanks.
    For comparison, the car browser loads my other sites https://ev-cpo.com really well, surprisingly, since I'm using some advanced javascript libraries in the newest version. The car browser also loads my old site trip tracking site: SuperCharger Trip Logger, which is essentially the same code base that runs EV-fw.com, so I'm at a loss right now why it's not loading in the car.
  11. HankLloydRight
    Connecticut
    Ok, I've made a few more changes, I think it should work better now in the car browser. Let me know. thanks.
