Flimsy Frunk lid.
kleppermaster
New Member
Jul 10, 2021
2
6
Cuba City, WI 53807
When I picked up my Tesla Model Y. I did a careful inspection and found only a couple things amiss. One was a poorly aligned door gap. The other was a slight bend in the Frunk lid. I took it to the Schaumburg, IL Tesla service center and they addressed both issues. However, they adjusted the Frunk lid lower and ever since when I clause it it oilcans. It doesn't make any difference where I push. The sheetmetal buckets and makes a oilcan sound. So far it doesn't look like it is causing any damage. It's just unnerving. for this to happen on a new car. I have decided not to use the trunk until this is addressed.
Has anybody else had this problem? any solutions?
Zhe Wiz
Go Big Red
Mar 15, 2021
142
219
Ithaca, NY
It is pretty weak. It’s also pretty easy to close. Still disappointing.
I’ve also considered adding a Tesla offer auto opener/closer partially to avoid having to push on it.
Can’t blame you for not using it. It’s by far the weakest hood I’ve ever fondled.
cypho
798
937
Here is a solution.
phayze one
304
675
LA (818)
The opening sound is so jarring and the closing method is so delicate. Luckily I don’t need the space because I try to use the frunk as infrequently as possible.
Flybuddy
344
348
Fort Myers FL
That was the main reason I went to the electric frunk. I installed the Tesla Offer and it works well. The price is a lot less than if you wrinkle the hood and have to fix it, plus you get get some excellent added convenience.
spokey
694
258
Flagtown
How hard was it and how would you rate your mechanical ability? Is it a job for the average person who say doesn't pull a rear axle but would perhaps change points, run a stereo etc.
Flybuddy
344
348
Fort Myers FL
I'm fairly mechanical and have built an airplane BUT I would have been able to do the install even with mediocre mechanical skills. Here's a good video on the install.
Reactions: spokey
cypho
798
937
It is not hard. As a test, try removing the frunk liner. If you do not have any trouble with that, you will ba able to install the auto-frunk kit
Reactions: spokey
spokey
694
258
Flagtown
thx. sounds easy. Already removed the liner once to take a look at the battery. memory tells me it was a little harder to get back on. Maybe aligning it or something. But not difficult.
DaveORD
732
641
Chicagoland
Small hands help. If you have big mitts like me, then those struts will be hard to replace, your knuckles will take a beating. That was worst of it for me. I should have gotten a neighbor or a neighbor's kid for that part, my hands were tore up for days. Driver's side is the hardest one to replace, passenger's side was not too bad.
Dennisis
655
567
Tucson
Here is a solution.
Watched the video but missed the discount code - any idea what it is? This sounds like a handy update!
jeffbco
682
385
Austin, TX
It's aluminum and designed to be lightweight to save on weight and extend the range. However, if you have to put instructions in the owner's manual how to place your hands when you close the Frunk in order to avoid damaging I kind of agree with you all.
Porsche 911's come with the same hood closing instructions in their owner's manuals
mark95476
1,703
1,039
Bay Area CA
You have to be really ham-fisted to mess-up your frunk. Here's Sandy kinda beating on his frunk. He found out later that he only needed to adjust the bumpers.
OG frunk: 911 with rear engine 👍
I bet a 911 hood is expensive, even before painting/matching.
@jeffbco not shocking, but those aren't daily-driving family crossover vehicles.
Reactions: srlawren
spokey
694
258
Flagtown
Nothing on a Porsche is cheap to fix or replace. Trust me, I dread any trip to the garage with mine... Never leave without spending $500 or more
A work friend of mine had a '79 911 that was a European version. Something about the headlights. He had to swap them for American spec every year for inspection. So he lost a screw to hold the bezel or something and we went to the dealer at lunch one day. Best I could tell it was just a normal metric screw. This was 35+ years ago so memory is probably a bit fuzzy but just an average screw that was maybe 1 1/2 - 2" (or mayhaps 3 cm) long. One screw cost $13.
BCKator
12
3
USA, CA, San Diego
The Porsche frunks are much more substantial than Tesla's model3/Y. I never use my Tesla frunk for fear of denting it. I'm careful w/ the Porsche but never afraid of using it. Tesla should fix this.
spokey
694
258
Flagtown
Mine was really hard as delivered and I felt the same way. There are two grommets(?) that you can turn. I screwed mine in a bit and it became much easier. Almost closes on its own now.
Reactions: Velcade
