620 miles range is no problem when you have a large gas tank and ICE like the C-Max Energi does.
If the solar panel could add 10-20 miles of EV range in a day while the car sits in the parking lot while you work, it may be worth while, but if it adds 1-2 miles like the Karma's panel would, it is not worth the cost or weight. The car would most likely be better served by simply putting a bigger battery into it, as that would result in more EV miles at a lower price.
I suspect the car is equipped with the ability to gradually move itself in sync with the focal light of the lens.But who moves the car throughout the day???
That is a good point. If the canopy requires AC power then my perceived main advantage is gone.I suspect that aligning the panel with the Fresnel lens will be challenging, especially considering that the car will not be positioned consistently and the sun angle is constantly changing. The panel will require a tip/tilt assembly and some way of aligning with the car. Sounds totally impractical given the amount of energy produced. Plus you'll have to route AC power to the Fresnel lens assembly for the computer, sensors, and actuators... in which case, as aaron0k suggested, wireless charging makes a heck of a lot more sense.
A panel of the size on the C-MAX only recoups about 2-3 miles of range. What no one has seemed to read at this point is, that the car must sit under a canopy of fresnel lenses to concentrate the size of the solar insolation footprint to the size of the car roof. This is the ONLY reason the car can charge with more power than an ordinary solar panel. No laws of physics being broken, just people who don't understand physics and don't want to learn, repeating parts of what someone else has said.
Obviously, having to park under a canopy wipes out any benefit of "going on long trips", as hinted in the article. You ain't takin' the canopy with you. At that point, you recoup the standard 2-3 miles per day of solar panel power.
And adding a panel to ANY car is simply an exercise in styling. It does not do enough to justify the cost. You have to park in the sun. You have to have the sun nearly straight overhead, as that is where the panels are pointed. It does not work at night or on cloudy days. All it will power would be a vent fan to cool the car interior with ambient air.
And imagine if you typically are not good at parking! The concentrating fresnel lens (Magnifying glass) can now make your car REALLY hot! This might be Darwinian justice to some people who can't seem to get a car lined up in a parking lot!
OK, Aaron0k beat me to it. But who moves the car throughout the day???
You're much better off just having standard solar panels feeding back into the grid so that you are getting power from them all the time, not just when you are home parked under the canopy.
