Ummmm wow. Why is all of that exposed?!
Because the cover tore/fell off...
I also noticed some strange round marks on the underside on left and right sides where it wraps under the bumper, not sure what those are from.
View attachment 371044 View attachment 371045 View attachment 371046 View attachment 371047 View attachment 371048 View attachment 371049
Build date was December, 2018. Here’s a few pics. Not sure how many bolts it’s supposed to have. I also noticed some strange round marks on the underside on left and right sides where it wraps under the bumper, not sure what those are from.
Thanks for the information. Build date was December, 2018. Drove slowly to service center this morning using back roads, so we’ll see what they say. Again, thanks for the feedback. Cheers.This is truly impressive. You are missing what is called the “M3 Mid Aero Performance” cover. It is typically held on by 13 bolts. I can only see the location of three of them in your pictures easily, and they are all missing. Presumably most of the rest are missing too.
Unless there was sabotage, this is Tesla’s fault.
Separately, your rear diffuser (this is the black plastic bit with the ribbed pattern on the inside, which is attached to the bumper cover (you can’t see the attachments)) is hanging on by just a couple bolts. I would pop the rear plastic covers and make sure those remaining 2 bolts are tightened right now. There are 5 bolts that are missing (at least). Two are shared with the mid aero cover (which are missing as previously mentioned). One goes in that middle missing bolt hole. The last two are a little further back in obvious bolt holes (the middle one of these holes does not have a bolt anymore in recent builds).
This is all Tesla’s fault unless there was sabotage. I would drive to a service center (slowly) and complain. If you cannot avoid freeways I would recommend mobile service for the 5 missing bolts before driving. It is probably possible to get a matching bolt (and washer) from Home Depot for *temporary* attachment for driving to service. You can take out one of the remaining two bolts behind the plastic covers and use it to get the appropriate size and thread pitch bolt at Home Depot, if you want to go that route with your $60k vehicle.
The aero cover does not need to be in place for short freeway runs though it will reduce loads on the rear bumper cover. That’s why that (the diffuser) must be properly attached before driving at speed.
This is an issue Tesla should give you a loaner for or fix immediately. I’m a little concerned the bumper cover may be warped now, but it might be ok. Just have to make sure it has all the attachments (there are two Torx screws and 6 clips in the wheel wells).
This is all something that can be fixed by a pro in less than an hour. Not major.
Your entire rear bumper cover and diffuser is in danger of falling off.
You can use this opportunity to take a picture of the plate on your motor (it is obscured in your picture, the square metallic plate on the left side of the rear motor). What is your build date? Which type of Model 3?
Bolt installers trying to keep up with the Model 3 production ramp / end of year rush:
Forgot to add that it’s a dual motor long range model, not the performance.Thanks for the information. Build date was December, 2018. Drove slowly to service center this morning using back roads, so we’ll see what they say. Again, thanks for the feedback. Cheers.
A bit late on the reply but yes, they endedDid they end up fixing it up for you today or did they give you a loaner?
When I went to get some of these bolts that I was missing, they said they didn’t have any (very odd!)...so maybe you’ll have to wait...
Anyway let us know when it is all fixed up.
Hey Alan. Just now got around to replying...anyway, they did fix everything so I’m good to go. Great service all around, no issues. They gave me a loaner Model S (I like my M3 way more lol), took about three days to fix. I’m assuming because the parts had to be ordered. Thanks again for the feedback. The car is amazing, really enjoying it! Cheers. - RickyDid they end up fixing it up for you today or did they give you a loaner?
@ricardo_1 I have the exact same problem! Although now that I've taken a look I realize I don't have anything cover both the rear and front motors! Were you only missing the rear composite material?
I got the car a few weeks ago and was hearing weird noises coming from rear from the day I got it. When it snowed the past couple days, there was a clear ground-scraping noise. I looked under, and the black plastic piece under the bumper had been scooping snow off the road and was being weighed down enough to touch the ground. The snow was super compacted in there.
@AlanSubie4Life ricardo showed a pic of his bumper cover coming off at the seam near the wheel well. Do you think there could be any damage there, e.g. the separation is stripping some threading?
Yeah, that's about the right place to drill it appears, if you feel it's necessary. I'm not going to worry about it, but in freezing/wet climates I might think about it. Overall I'd be pretty loathe to drill it though! I've attached a picture of the upper side of where you drilled; you can see there is a lip which would definitely accumulate a little water (which you have eliminated). I suspect eventually a small hole will get plugged by dirt and rocks though (same issue as the undercover will have - you bring up a good point - it may be that if these drain holes get plugged that the water weight would be too much - I'm not sure).
In wet conditions, yeah, it's really hard to predict exactly how these things will behave, it's very hard to know exact how water will be splashed & channeled. All you can do easily is make sure you have all the bolts! Note that for the bumper cover, there is actually one bolt that you can't see, which is located on the forwardmost edge (middle hole in the picture below), underneath the undercarriage cover (this one is unlikely to be missing though since I don't think it can fall out even if it loosens). So there are 7 (2+2+3) (or 8 (2+3+3) for some early cars) attachment bolts on the bottom side of the rear bumper cover. This is explained in most hitch install videos, though sometimes it isn't obvious.
I'm considering drilling this hole. Is it still agreed that this is the best spot? And just to confirm, this is slightly on the passenger side of the center line, correct?
Yeah, that is about right.
Personally, I would not drill. I would determine if I had a problem by removing the three (you might need to remove a couple from aero under cover as well) bolts and seeing whether there is an accumulation of dirt. Or: modest amounts can be flushed by parking the car pointed downhill and flushing copious amounts of water through, starting from the trunk area, I think.
I just don't like the idea of water accumulating
This is horrible. Has Tesla declined to fix this issue?
