Thanks for the work, I’ll have to check and see if I’m missing any of those bolts. I watched one of my videos and see where it’s possibly draining from one of the holes you indicated. On the attached screenshot I marked that possible hole location and the spot where it overspills, which is where I first spotted after car wash.I have news on the rear undercarriage cover (not the rear bumper cover). I put the back of the car up on ramps to get this information.
Attached are a few pictures. If someone has the middle bolt on this cover, please let us know and provide a picture. I especially wonder if the early builds had this bolt? (I'm not talking about the bumper cover middle bolt which we've already discussed.) I'd like to have this last bolt inserted, because it seems to snug the cover up against the bottom of the car by a fraction of an inch. But it might take some forcing to get it past the cover due to the misalignment.
- There are 12 10mm bolt/washer combo attachment points for the cover. There is actually a spot for a 13th in the middle, but my car didn't have that (the threaded hole and the cover hole didn't align too well - and it looked like a bolt had never been inserted).
- There are multiple drain holes. They are located at the lowest points. Water is not going to accumulate on top of this cover.
- There are several other attachment points at the edges of the cover near the wheel wells, with rivet like joins to metal bars which run above the cover. There are also attachments on each side to the wheel well composite shield.
The summary is: This undercarriage composite is quite robustly attached (assuming all bolts are present), and it seems very unlikely that it will sustain damage unless it is not properly attached, or something hits it and damages it.
I definitely don't think car washing or it getting soaked is going to be an issue at all; it's just too well attached & well drained. The effect of snow and ice is a little less clear, but it also seems unlikely to be an issue unless it is a very bad icing situation, or you're driving in deep snow and throwing up a lot of it. It looked to me like the snow being thrown off the wheels would tend to be diverted from landing on top of the cover.
So, as far as the OP goes - I continue to think the damage most likely occurred because the cover was never properly attached. Or, it sustained damage somehow inadvertently, due to road debris.
Definitely no need to do anything to it, other than to make sure it is attached - it's been solidly engineered to remain attached to the vehicle, as far as I can tell.
My early August build has all 3 bolts in the plastic cover areas.
I can’t see far enough under my car to see how many of the bolts for the composite cover are there/not there.
Tesla has new trunk weather seal design, it might be better at keeping the water out.![]()
Interesting. Did they add an additional seal?
The new weatherstripping will keep water out of trunk but not out of bumper cover. Water enters bumper from behind tail lights. This is the same seal installed on my vehicle after I found my old one had a wide gap to bumper.Tesla has new trunk weather seal design, it might be better at keeping the water out.![]()
It felt like one piece so not and additional seal but a redesign of the old seal with better coverage.
How does this new seal keep water out of the trunk? While it is certainly more aesthetically pleasing, it seems like that gap with the old sea just lets additional water (in addition to the water coming behind the lights) behind the bumper cover - the trunk should still be sealed - because isn’t the only opening to it this seal around the trunk lid? (Which either seal works to seal.)
Yes, both weatherstripping designs keep water out of trunk, I’ve never had water in mine. If someone gets water in their trunk it must be because they didn’t close trunk all the way which has happened to me a couple of times. My concern with gap on my old weatherstripping seal was with water entering the bumper. SC told me nothing would be damaged by water going in there but that they would fix the seal for me. After I had the new seal installed is when I noticed water still entering bumper cover from behind tail lights. The tail lights have small sealing gasket on mounting screws but as you can see on attached image, it’s a cheap seal which might eventually let water seep into trunk.How does this new seal keep water out of the trunk? While it is certainly more aesthetically pleasing, it seems like that gap with the old sea just lets additional water (in addition to the water coming behind the lights) behind the bumper cover - the trunk should still be sealed - because isn’t the only opening to it this seal around the trunk lid? (Which either seal works to seal.)
Yes, I had the same gap on lower left corner. I was told they had to remove bumper and readjust the seal but when I look at the before pictures it looks like it’s a different seal.@Redrick00,
Is this the same wide gap to bumper in the lower left/right corner of the trunk/seal as in my photos? Have a Ranger coming tomorrow to look at same issue.
SkiView attachment 357465View attachment 357466
I have the same gap in the lower left corner. As others have said, it seems to lead into the bumper. Please let us know what the ranger says.@Redrick00,
