Front Window adjustment
Is there any sort of adjustment to change how the front door glass sits? My passenger window seems to be angled outward compared to the driver door (see direction of arrow). This makes the upper corner of the glass not sit snug on the door seal and makes for lots of wind noise. Had service out twice...first they added foam then a new door seal and both times didn't really fix the issue. If the window could be adjusted so it leans inward more (opposite the arrow) it would press more firmly against the seal and fix my issue.
Any insight would be appreciated.
Thanks kindly.
There are a few threads on this and SC and MS staff should know adjustments are possible and how to make them...
You can attempt do perform the same yourself if you dont mind taking the door trim off, marking a few things and potentially having to adjust a few times.
PSA/NB - Even after adjustment, it may not fix the issue you think it should/could. Sometimes its all thats needed, other times you have to change the weather stripping/seal, sometimes the glass element... and even after all of that and more, issues persist.
Reactions: nvesprini
