Garage Door Opener
Discussion in 'Model S: User Interface' started by Chet, Jun 30, 2014.
  1. Chet
    Chet Member
    Dec 11, 2013
    Tustin, California
    The garage door opener on my MS ceased working. The wall switch worked, so I figured the problem was in the Genie opener because re-syncing the MS failed to solve the problem. I called the service that installed the Genie Garage Door opener and he found that "all the codes had been used up." (Do not ask me to explain that.) He erased all existing codes and I was able to sync. If you need help on this, you may contact call HomeLink help at (800) 355-3515.
