What is that, hard-packed dirt and gravel? At least you can keep working on it to make it more gradual. The plank idea is a good one. Try to give your self a healthy margin if you can.
So I went outside and measured my driveway. It goes 30" vertical for 145" horizontal where it connects to the road. My roadster handles the transition fine, but will bottom out (a little) if I take it too fast. I also often enter the driveway at a bit of an angle which helps.
PIX
I know its the not the ideal solution, but if it is a problem maybe having a couple of boards/ramps available to reduce your grade a little. Put them up before entering/leaving and remove after pulling in/out.
Of course parking on a slope causes all the electrons to roll to the back of the pack, so the estimated range will no longer be accurate.
....it's probably expensive but.....
Awesome! Congrats. So you didn't need to do anything to the driveway after all? I think you just had too long to think about your driveway I guess=)
