Good point. It might be because of that German teen who hacked 3rd party apps that held people's access token.
Make sure you're using UTC with the dates:I can't get time_of_use_energy to be recognized with start_date. It just sends "upstream internal errror" back.
kind=power still works for me except for the ever widening hole in the beginning of December.
url = ('https://owner-api.teslamotors.com/api/1/energy_sites/'
+ SITE_ID
+ '/calendar_history'
+ '?kind=time_of_use_energy'
+ '&period=' + period
+ '&start_date='
+ datetime.strftime(
s_date.astimezone(pytz.utc),
'%Y-%m-%dT%H:%M:%SZ')
+ '&end_date='
e_date.astimezone(pytz.utc),
Python 2.7:
url = ('https://owner-api.teslamotors.com/api/1/energy_sites/' + SITE_ID + '/calendar_history' + '?kind=time_of_use_energy' + '&period=' + period + '&start_date=' + datetime.strftime( s_date.astimezone(pytz.utc), '%Y-%m-%dT%H:%M:%SZ') + '&end_date=' + datetime.strftime( e_date.astimezone(pytz.utc), '%Y-%m-%dT%H:%M:%SZ') )
So this is using a start_date in local (Pacific) date/time Jan 12, 2022 00:00:00 and an end_date in local (Pacific) date/time Jan 12, 2022 23:59:59 then converting it to UTC into the URL below:Can you turn that into sample URL minus your token so that I can curl it. I'm using UTC times with Z on the end of the date/time string. Same as I'm using for end_date with kind=power.
https://owner-api.teslamotors.com/api/1/energy_sites/<SITE_ID>/calendar_history?kind=time_of_use_energy&period=day&start_date=2022-01-12T08:00:00Z&end_date=2022-01-13T07:59:59Z
I experienced the same. The access and refresh tokens are a much longer length and the access token expires in 8 hours instead of 45 days. You can use the same refresh token to generate a new access token more frequently now but the URL and parameters are different.
I read the article. It was not "hacked third party apps" it was "Found people who had used Teslamate, which is a SELF HOSTED tool, who had set it up incorrectly (likely not changing default passwords)".
I patched the data holes by downloading from the app for those days which was tedious and the resolution is in 100 watt increments so I'm likely to be off a few percent for those days unless they are leveling between the 5 minute increments with carryover and carryunder NOT to cross one hour boundaries.
Bummer... not that the tokens are longer, but they only last for 8 hours. Can you still use refresh tokens to generate new access tokens? That's easy enough to script. But the full reauthentication to generate new tokens is a pain due to the Captcha.
Oh yeah, that's a daily summary. For the 5 minute increments I use: /powerhistory but that only gets the previous day. There must be an endpoint that you can query for a particular day because it's available in the app.For me this "kind" isn't producing hourly data.
Yes though it's a bit different than before:Bummer... not that the tokens are longer, but they only last for 8 hours. Can you still use refresh tokens to generate new access tokens? That's easy enough to script. But the full reauthentication to generate new tokens is a pain due to the Captcha.
url = 'https://auth.tesla.com/oauth2/v3/token'
payload = {
'grant_type': 'refresh_token',
'client_id': 'ownerapi',
'refresh_token': REFRESH_TOKEN,
'scope': 'openid email offline_access'
Though I don't use calendar_history, kind=power, I played around with it and I was able to get data for period=day in 5 minute increments. Oddly enough nothing came up for Dec 9 but Dec 10 had values. Here's what I used:The data loss continues. Now the December 9th and 10th are gone.
local = pytz.timezone(TIME_ZONE)
date = local.localize(datetime(
date.year,
date.month,
date.day,
23,
59,
59,
0
), is_dst=None)
+ SITE_ID
+ '?kind=power'
+ '&end_date='
+ datetime.strftime(date.astimezone(pytz.utc), '%Y-%m-%dT%H:%M:%SZ')
+ '&period=' + period)
local = pytz.timezone(TIME_ZONE) date = local.localize(datetime( date.year, date.month, date.day, 23, 59, 59, 0 ), is_dst=None) url = ('https://owner-api.teslamotors.com/api/1/energy_sites/' + SITE_ID + '/calendar_history' + '?kind=power' + '&end_date=' + datetime.strftime(date.astimezone(pytz.utc), '%Y-%m-%dT%H:%M:%SZ') + '&period=' + period)
Yeah this changed a few months ago and I stopped trying to keep up with all the changes, relying on the refresh token. There's a long list of discussions on Tim Dorr's Github with varying solutions.I'm having trouble generating a new access token from the full 4 step login process outlined on this page:
Authentication | Tesla JSON API (Unofficial)
The authentication process for the Tesla APItesla-api.timdorr.com
Has Tesla changed this as well? It fails at Step 2. I do the login and get the Captcha at Step 1, but Step 2 to obtain an authorisation code returns
Access Denied
You don't have permission to access "http://auth.tesla.com/oauth2/v3/authorize?" on this server.
