I have never seen this type of behavior in the two years I've own and monitored my Model 3.Plugged in. Look how many times it fed itself in 15 hrs. This is plugged into 48amp / 240v View attachment 609726
Just curious which app are you using for this information?Plugged in. Look how many times it fed itself in 15 hrs. This is plugged into 48amp / 240v View attachment 609726
teslafi doesn’t recognize the slight charges either. Maybe you have another program that does?I have never seen this type of behavior in the two years I've own and monitored my Model 3.
Do you have Sentry Mode enabled? Or was it particularly cold?
It’s the native ChargePoint app that is used with their chargers.Just curious which app are you using for this information?
Correct. The small amount of differences in battery degradation between 80%, 70%, and 90% for a short time isn't worth bothering about. Besides, there are other factors that affect degradation that aren't related to the state of charge which can easily override the set level. As long as you don't leave it at above 90% or below 20% for a long time, there's going to be little difference in the battery life. My early 2013 S 85 had about 8% degradation after 130K miles/7 years. (Mostly charged to 90% except for trips when charged to 100%.)I agree. But, why not. It’s easy. If I forgot and left at 90 I wouldn’t worry about that either.
20% SOC is not a meaningful low SOC limit. The pack storage guidance Tesla provides in the EPA applications is: “To maintain service life, the battery pack should be stored at a state of charge (SOC) of 15% to 50%.”As long as you don't leave it at above 90% or below 20% for a long time, there's going to be little difference in the battery life.
The Tesla wakes up occasionally and charges the 12V battery. But start at 90%, not 100%. And don't use the App to check on it, that wakes up the Tesla. The Tesla is programmed to go into a deeper sleep the longer it's left unattended. Note that many airport parking lots have places where you can plug in 120V is enough (the ride to the airport parking lots have them too), so look into that.I'm not the OP. But say I live in an apartment complex with no way to plug in, and I need to leave for 6 weeks. Is it fine if I leave it unplugged outside?
I don't have any friends or relatives nearby with a garage/driveway.
How long will the Model Y last if I leave it at 100%, with all the features turned off? (cabin overheat, sentry, etc).
My guess is that the 12V battery might be dead after 6 weeks, unless the Model Y recharges it as needed even if unplugged.
1. Storage is not regular use, and this chart looks as if it's for storing the battery that is not in the car.20% SOC is not a meaningful low SOC limit. The pack storage guidance Tesla provides in the EPA applications is: “To maintain service life, the battery pack should be stored at a state of charge (SOC) of 15% to 50%.”
Here is data that shows a significant difference in Li-ion battery capacity retention when stored at 15% verses 90%.
Ref: https://res.mdpi.com/d_attachment/applsci/applsci-08-01825/article_deploy/applsci-08-01825-v2.pdf
