Help with large solar installation estimate
Discussion in 'Energy, Environment, and Policy' started by RubberToe, Feb 17, 2015.
  1. RubberToe
    RubberToe Supporting the greater good
    El Lay
    All,
    Hopefully one of you can help me out with a very rough order of magnitude estimate for our condominium complex. Here is the story: We had looked into solar panels several years back (~5-6) when I was not on the HOA board. The answer back then was that it was not cost effective. Since then our rates have increased (surprise!) and panel costs have dropped significantly. We just did a building remodeling project that cost about $120,000. It's a 50 unit building. And we do a remodel about every 10-15 years depending on how things wear and who is controlling the money.
    Eventually I will be the HOA President again, and I want to get solar panels put onto the building. I would like to send an e-mail out to the board and some residents who are very pro solar power to let them know either: 1) What $120,000 can do with respect to putting a system in, and how much we would save monthly, or 2) If our system would cost less than $120,000, how much would it cost to offset all our power consumption? It seems like a good time to get people thinking about how it might be a good idea to invest some money in something that will pay monthly dividends versus cosmetic things.
    Here are the monthly details for both July and December so you can get an idea how much power and cost we are talking about:
    July: Kwh/Day was 166 (5,146 total Kwh), and the power bill was $970 ($0.188 per Kwh)
    December: Kwh/Day was 199 (6,169 total Kwh), and the power bill was $1,140 ($0.185 per Kwh)
    Building is in zip code 91101. I'm really curious to see what our system payback time would be now.
    Thanks in advance,
    RT
  2. johnnyS
    johnnyS Member
    One of the members on this forum has worked with a number of Tesla owners: Danny Wang <[email protected]>
    He is located in Irvine
  3. deckofficer
    deckofficer Member
    Northern & Southern California
    #3 deckofficer, Feb 17, 2015
    I have been so impressed by the knowledge pool on TMC, I'll preface my guesstimate with "I know someone will give a much more detailed response than me" so wait for better expertise than mine.
    It has been 20 years since I did off grid power, but today I think $1.50* per watt installed should cover it. At $120K that would be an 80 kW array. In your location (zone 2 at least) count on 5.5 hours average yearly. So 5.5 X 80kW X 0.12 X 365 = $19272 per year production @ $0.12 per kWhr.
    * I base this on current solar going for $1 per watt. Last panels I bought 20 years ago were $5 per watt, so with utility rates at $0.12 kWhr it was only viable for remote, off grid homes. Now with the large drop in prices, explains Elon's involvement in solar.
  4. Saghost
    Saghost Well-Known Member
    Delaware
    Deckofficer took a reasonable initial approach, but I'm not sure I understand the direction he went with the numbers overall.
    If your goal is to match your annual electricity generation, you start with the 5.5 hours average insolation for the region and your average daily use - assuming it moves smoothly from the 166 to the 199 and back, it seems like you need to average about 180 kWh/day. This will produce excess power in april, may, and june, and be short in december and january - but if the power company net meters they'll carry it across.
    To average 180 kWh per day in a 5.5 hour area, you need about 33 kW of AC nameplate rating (maximum power production after inverting and whatever losses the orientation induces.)
    When I bought my panels a little over three years ago, I paid a little over $4 per watt installed, with the fancy microinverters.
    Prices have continued to fall since then - I was thinking you'd be paying more like $2 per watt than his $1.5 - but even then, I'm only talking about $66k to produce as much power as you currently consume. There's also an unlimited 30% of installed cost federal tax credit for individuals that put in solar - I'm not sure if your HOA could benefit from it in some fashion or not.
    At ~$1000 per month you aren't paying, you'd make the initial cost back in ~5 years assuming net metering and no rebates.
    Walter
  5. RubberToe
    El Lay
    If I have this right, it looks like an 80kW system will generate 80*5.5*365 = 160,600 kWh per year, which is way more than we need. I believe our worst case would be 6,200 kWh per month or 74,400 kWh per year. Thats about half the size that $120k would buy, so maybe our system would run $60k? If that covers our entire yearly bill of say $13,000 then the payoff period would be 4.6 years? :eek:
    If thats right, I need to make some phone calls starting tomorrow :wink:
    RT
  6. Xenoilphobe
    Xenoilphobe Active Member
    Fairfax County Virginia
    You might want to build excess capacity to cover the 10 HPWC Tesla Chargers that you could install for the condo community.....
  7. RubberToe
    El Lay
    Saghost,
    Looks like we crossed in our last two posts. Wow, a 5 year payback time. Almost has me wondering why every condo building in Pasadena isn't covered with solar panels already? Am I missing something?
    RT
  8. Saghost
    Delaware
    #8 Saghost, Feb 17, 2015
    Solar prices have only been that low very recently, and it takes time for folks to get around to it. A lot of people probably looked a solar a decade ago and still have those prices and paybacks in their heads.
    Also note that this analysis assumes net metering - something that has been common for solar for a long time, but the utilities have been trying to change lately - they end up having to carry a lot of spinning capacity to handle potential changes but can't charge solar customers for it or the infrastructure that you're using (though you're also reducing peak loads and helping them need less infrastructure overall.)
    It'll be interesting to see how this evolves - one likely answer which Tesla is betting on is distributed battery storage - one of their 400 kWh pallets at your local transformer would greatly reduce the fluctuation in grid demand, and provide some backup capacity for customers in an outage situation as a side benefit (and if they keep power from the battery to your panels, your panels can keep the neighborhood running for a while longer, too.)
    Another piece of it is likely some sort of billing change - in Arizona they tried adding a fixed fee to all solar customers and it was denied by voters. Some additional billing will likely happen eventually - possibly in the form of a demand charge (an item on the bill based on the number of kW used in the highest fifteen minutes of the billing period) or some sort of capacity charge (something I've never seen before, but it would be basically charging for how much of a "battery" they are being for you - it'd aggregate (average? Highest night?) the daily swings in your meter, so that someone who used five kW at night and put them back in the day got one fee, and someone who used fifty at night and returned them in the day would pay 10x as much.)
    Of course, if the new fees they eventually decide on become too high, then complexes like yours will just buy their own battery packs from Tesla - if you believe the $100/kWh price some folks have tossed about, one of those pallets would only cost you another $40k now or in the near future, and would let you live almost independent of the grid (but we sized the panels for average use - you'd come up short in the winter months unless you added panels.) With prices of panels and batteries low and falling, it seems like cheap clean power is likely in the future. :)
    More storage and more interconnection is the key to making renewable energy work - but that costs money, which the utility isn't getting from net metered customers, so the current model is unsustainable in the long term as the percentage of solar customers increases - but right now I don't think you're missing anything as the current laws and rates read. Get your panels paid for while the getting is good. :)
    Walter
  9. Cosmacelf
    Cosmacelf Well-Known Member
    San Diego
    How much roof or ground space do you have? Building a large solar array requires .. large areas to put the panels...
  10. wws
    wws Member
    Northern California
    I just had a 3kw system installed last December. A price of $1.50/watt installed sounds too good to be true. Figuring panels at $1/watt and microinverters about half that, leaves almost no room for racking, roofing work, electrical work, etc. A more likely figure is probably closer to $4/watt range installed. Then if you qualify for the 30% tax rebate, it gets under $3/watt.
    How much of your bill is Tier 1&2 vs Tiers 3&4? When sizing the system, it really pays to size big enough to eliminate the higher tier usage to get best ROI. After that, the ROI is much longer.
    And yes, net metering is a great thing.
  11. Saghost
    Delaware
    #11 Saghost, Feb 17, 2015
    This is true. It looks like current generation cheap panels are getting almost 15 W DC per square foot:
    http://www.wholesalesolar.com/products.folder/module-folder/Astronergy/CHSM6610P-260.html
    Allowing for inversion losses and siting issues, I'll assume 12 W AC per square foot - meaning you'd need something on the order of 2800 square feet covered by solar panels.
    (I don't know anything about your building's layout - for traditional sloped roofs they aren't supposed to be near the very top or bottom of the roof, and they usually come in ~40"x~65" panels like the one I linked, so you might need considerably more south facing roof space than that to install the panels (ground/post mounted systems are also options)
    Walter
  12. wws
    wws Member
    Northern California
    One other thing: In theory, south facing modules may generate the most electricity. But given Time-of-Use metering, you generate more valuable electricity during prime time, then buy it back at night at a lower rate. In my case (E7 TOU) prime time is noon-6 pm, so west facing modules might actually generate a better return dollar-wise. I have a mix of south and west facing modules with microinverters to optimize each module. One can clearly see on the web monitoring software the inverters on the south facing modules turning on and off earlier than the west facing ones. If/when I add on to the sytem it will be on the west facing portion of the roof.
  13. tomas
    tomas Only partially psycho
    Chicago/Montecito
    #13 tomas, Feb 17, 2015
    This is the "industry standard" estimator for how much you will generate. Factors in your location. Better to show you where to fish than send you a fish, as you will be able to point to a real source (rather than some guy on the forum) when you pitch to your board.
    PVWATTS
    And, here's a good article on per watt installed prices. There are many sources, but make sure you only look at 2014 studies or reports. There's lots of old stuff that shows up on google.
    It really does not take long to become conversant on this stuff, good luck.
    PS, The two major components are panels and inverters. There are many different capacity of panels... generally the higher power ones cost more, but also generate more (in same space). Be realistic about how many you can fit on your roof... it would probably make sense to have a pro take a look before you get to tied up in numbers. There are two options for inverters (that is, DC to AC conversion). One is string inverters... large boxes, usually inside building, that handle a string of panels. The other is micro-inverters, which attach to back of each panel. There are a number of advantages to micro inverters: there's less loss between the panel and your use, they allow monitoring of generation by panel (which is useful for troubleshooting), and they allow you to expand the system easily (even to the point of using different types/capacity panels in future). They cost a bit more, but I personally would recommend.
  14. deckofficer
    deckofficer Member
    See RT, I told you wiser minds would drop by, listen to them, not me, my knowledge is dated 20 years and off grid. Some of my old installs were rather interesting and a learning curve.
  15. Saghost
    Delaware
    Huh. My installation was cheaper than the 2012 listing in 2011, despite the installer specifying US made panels and the more expensive micro-inverters. I guess I was luckier than I realized. :)
    Walter
  16. Cosmacelf
    San Diego
    A lot depends on the specific site challenges. Electrical Panel upgrades, how long the thick cable runs need to be, how awkward the roof is, etc.
  17. RubberToe
    El Lay
    #17 RubberToe, Feb 18, 2015
    Here is the roof:
    South is down. It is a 3 story building. The entire building is electric except for the jacuzzi heater which is gas. The primary electric consumption is hallway lighting 24/7, recently switched to LED, and garage lighting, which we switched to all motion detection about 5 years ago. Each unit pays their own units power cost, the HOA just pays for the common area costs.
    I like the idea someone mentioned previously about possibly installing extra capacity for car charging. If a 40kw system requires 200 panels, the roof provides plenty of room for likely 5x that number. The other interesting thing is that people living on the 3rd floor have electric bills that are much higher than the other floors due to being right below the roof. Building was built in 1970, and not sure what kind of insulation is under the roof. I'm also thinking that to the extent we put up panels and they block the sun from hitting the roof, we are going to lower the cost of cooling for the 3rd floor residents. Not clear to me how much of an effect that will have, but many 3rd floor residents have told me that their AC runs 24/7 and the temperature never gets below 80 degrees in their unit. This could be a capacity issue too.
    The 17 horizontal and vertical things you see are each banks of 3 AC units. Coolent pipes run down to the 3 units in each stack. I'm assuming that it would be good to place the panels so that the AC units are in the shade? The current roof is about 7 years old, and we heard about 2 years ago that it should last another 7-10 years. I will contact the city to confirm whether we have net metering available at the complex. Thanks for all the good information!
    Another possibility is heating the pool with a solar thermal system to expand the period where the pool is warm enough to swim in. Might as well put the Sun to good use :cool:
    RT
  18. wws
    wws Member
    Northern California
    So it is a flat/level roof? Then you can use the entire roof. The racking will be tilted to optimize collection.
    Also, since you say the primary electric load is hallway lighting, changing to LED was a great idea. The difference in efficacy/power usage over incandescent can be a factor of 7 or more. Are the monthly power costs you quoted earlier before or after switching the lighting? If before, you should look at the usage afterwards - since that will drive the number of PV modules you need downwards.
    Net metering is a function of the power company, not the city. Once the system is installed and the city building inspector signs off on it, there is a simple application process to e-file at the utility company. (Your solar installer will help you do this.) In my case (PG&E) it took about two weeks for them to approve and enable net metering. Up until that time, the power usage would floor at zero kwh used. After they enabled it, the meter can run backwards. There is also a reconciling process where if you generate more than you use on some days/months it will balance out other days/months of lower production.
    Solar hot water heating for the pool is a great idea too.
  19. CHGolferJim
    CHGolferJim Member
    Chapel Hill, NC
    I skimmed this, but don't see any mention of depreciation and maintenance expense impacting payback. A hurdle for single family residences (not the OP's case, of course) in my mind is mobility = why pay upfront cost of installation if I may not be here. Are people seeing part of installation cost reflected in higher selling prices to minimize that concern?
  20. Saghost
    Delaware
    #20 Saghost, Feb 18, 2015
    A properly done modern array shouldn't have meaningful maintenance expenses - the panels and inverters are solid state devices that just sit there and generate power, and the rain is usually adequate to clean them off.
    I'm not sure what you have in mind for depreciation - I guess a business could possibly take credit for the depreciation as a tax offset?
    I'm not even an expert in my personal taxes, let alone all the business tax rules.
    For the mobility aspect, I was promised that the reduced utility bill would result in higher home selling prices, but I have no experience with that. A real estate agent said that for every dollar saved on monthly bills a house was worth an extra hundred dollars on the market?
    Walter
