Help with universal mobile charger for roadster
Discussion in 'Roadster' started by Chickenlittle, Dec 5, 2014.
Tags:
  1. Chickenlittle
    Chickenlittle Active Member
    Virginia
    Hi bought roadster 2.5 used came with three chargers. I use the high capacity charger without problem. Just installed a 50 amp 240 outlet to use the mobile charger. The outlet tests at 250 volts. When plugged into the outlet no red light when test button pressed. When plugged into the car I get the usual blue light followed by a brief red the car is not charging. I have tried 40 amp rate and 32 amp without change. Any ideas on how to trouble shoot? I don't have another outlet with that type of plug
    had bought nema 6-50 connector and installed that outlet. They have been out of the 14-50 plugs for a while. It's hard to find another 6-50 outlet to try it on.
  2. NigelM
    NigelM Recovering Member
    Sarasota, FL
    Are you getting any lights on the UMC for "power" or "charge status"?
  3. Chickenlittle
    Virginia
    Yes charge status green.
    charged car with high power wall unit and used lower current out of couriosity and no issue.
  4. strider
    strider Active Member
    NE Oklahoma
    Does it switch to red when the car tries to start charging (it flashes blue and you hear the clicks like it's trying to charge and then it goes red and stops charging)?
    Is the 6-50 properly grounded (ground pin needs to go to ground and not neutral - the 6-50 doesn't have a neutral pin) and have you verified you indeed have 2 phases of 120V? With a multimeter you get 240V across the hots and 120V from each hot to ground? Not denigrating your electrical skills, just covering the basics.
    Does the car give you any kind of message on screen when it stops charging?
  5. Chickenlittle
    Virginia
    It is grounded and is 250 across hits and 124 each hot to ground. Didn't see code in car after trying to charge. Yes it does flash blue and click then brief red. Will on its own try again then brief red. It came with car but I never used it personally. Recently got the 6-50 adapter wonder if that could be issue?
    - - - Updated - - -
  6. bonnie
    bonnie Oil is for sissies.
    Columbia River Gorge
    Is there another Roadster owner nearby with a UMC you can try? And have them try yours? It's very likely a bad UMC - they're notorious for short life span.
  7. Chickenlittle
    Virginia
    Thanks all for responses. Will stick with high capacity wall charger for now. The mobile was to be used as a backup
  8. CSPHD
    CSPHD Member
    Alabama
    The UMCs are widely known to be problematic. My first one died a mysterious death with a flashing error code that no one was able to explain. My second one only works in cold weather or if I use a fan to cool the electronics module during charging. In troubleshooting my UMCs, I monitored my 50 amp circuit (NEMA 14-50 receptacle) and observed that all was well when I had 118v to 123v hot-to-ground. Anything outside that range and the car threw an error, lowered the current, and attempted a restart. It would ultimately end up at 20 amps and unable to charge until the voltage was in back in range. The car would charge on the spare cable fine even when the voltage was out of this range.
    FWIW I've tested with a Clipper Creek HPC-40 in both cold and hot weather and it worked flawlessly.
  9. Chickenlittle
    Virginia
    Actually wonder if none knows whether the mobile connector was covered under new car warrantee? I still have four months left on that
  10. bonnie
    It was only covered for the first 12 months originally.
  11. NigelM
    Sarasota, FL
    As others have said/implied it's highly likely a faulty UMC. I'm doing fine with my Clipper Creek but always take the J1772 adapter with me when I'm going longer distances.
  12. wycolo
    wycolo Active Member
    WY
    Have you actually run a load on each leg of the wiring like a toaster or a 3/8 inch drill motor?
  13. Chickenlittle
    Virginia
    Have not. Not sure how that will help. Thinking when roadster goes in for service may ask tesla to check it out. Not an issue now use hpcw
  14. wycolo
    WY
    Running an actual load on new wiring, as opposed to just using a test light that draws no wattage, will uncover loose connections. Has happened to the best of us.
