yes.I am looking at the best way of charging at my business premises, we are currently having a quote done for a Zappi. The installer has mentioned that we will need PME near the main incoming supply that will need to communicate with the Zappi located some 15 mtrs away on a seperate RCD Board. We have 3 phase so would like the option to charge at 11kw. I havent received the quote yet but I suspect it is going to be fairly expensive.
We do have a redundant 16A 3 Phase Commando socket located within 6mtr of where I am planning on charging the car. Could I just plug one of these in and start charger from that socket instead?
Tesla - Multi adapter Charger. 3 Phase 32A / 16A. 3 Pin and Commando EV Charger. Type 2
Type 2 Tesla 1 Phase to 3 Phase 6A - 32A Multi Socket EV charger. 6A, 8A, 10A, 13A, 16A, 20A, 32ACharge your Type 2 Tesla EV using multiple power sockets including the 3 Phase 32A and 16A Commando (CEE) socket, 1 Phase 32A and 16A single phase CEE socket and the 3 pin mains / household socket. Ywww.evchargingcablestore.com
Any help would be appreciated.
you need either this one in your link... or this one which is from Tesla.
Blue Adapter - 16A/32A
Combine with the Gen 2 Universal Mobile Connector to plug in at standard single-phase socket with higher power output. 16A Blue Adapter Plug Diameter: 42 mm Max charge rate: 3.7 kW Range per hour: 22 km with Model 3 17 km with Model S...
shop.tesla.com
I see that 16Amp adapter is out of stock, but 32 Amp is available. but price is significantly lower..
you just plug it into standard tesla mobile charger (instead of 3 pin adapter - these are interchangeable)
