Thanks to all in advance. How do 90 degree temps affect Model 3 range? I’ve got the AC running at about 6 or 7 at low, and my wh per mile is around 350. Thoughts greatly appreciated.
Thanks man. I appreciate your thoughts. I’m guessing that on a longer drive the cabin temperature would stabilize and wh per mile would go down.Just cabin cooling running hard, guessing the drive was short and still trying to cool further, longer drive the AC use should fall some.
Thanks Darth. I love “That’s Nothing “. For me all this isn’t a huge worry because I don’t drive much or do many long trips. Just my first experience driving in 90 degree temperatures. The AC in my 3 is really good. No COP on. Pre cooling with charger connected is a great idea.350 Wh/mi is nothing ... check out my nearly 1500 Wh/km trip
Trip meter counts energy used while stopped (in Drive, but not in Park) - with test results
That’s over 2400 Wh/mi!
(This was a VERY short test trip)
So yes, consumption effects from HVAC will average down after an initial high usage. If you pre-cool the cabin or cool it down while still in park before you depart, then your trip meter will only show the ongoing HVAC usage to keep things stable at your set temp, which is lower than the usage in the first few minutes of intense cooling of a hot cabin. If you leave it on auto with a comfortable set temp you should be fine and not affect consumption greatly. If you leave it on “LO” all the time the AC may never rest and use a bit more power. I found my consumption dropped a bit as spring temps warmed up to summer. The little extra AC usage was actually beaten by the savings of the car operating at more ideal warmer temperatures.
If you have Cabin Overheat Protection on, it keeps it below 40C/105F and I’ve found it only takes a few minutes to cool the cabin down before a trip from that point if I remember to pre-cool from the app to a comfortable 20C/68F or so.
Folks, the Tesla, like all evs, have electric ACs. This means cooling much faster than ice, because you don't have to wait for speed for the compressor to kick in, same for heating. So while you may be used to staying hot in an ice, no longer the case
