If it is 2 feet away from your panel, that's dramatically overpriced.
$270 for ~50ft through an unfinished basement to the garage.
did that include the wall connector?I’m in Ma, called Tesla and they quoted me $1500 for under 100 feet from my breaker or $1800 for over. Is this reasonable? What have others done?
They roll in an hour or two of labor for getting the permit I’m sure.For installing NEMA 14-50 Outlet I got a quote for $985 ($785 for Parts + Labor and $200 for Permit). It needs 50 feet #6/3 wire run from the main panel in my unfinished basement.
I looked up the parts available from local lowes store and It came to $186 after tax.( it could go down by another $30 if I used coupons).
Electrical Permit would cost me another $75.
After this I have decided to do it myself.
I have my M3 delivery scheduled for 9/22.
I'm using my UMC to charge. I installed a 14-50 outlet myself. 45 min worth of work, $60 in parts total. Electricians are sometimes a little too greedy. I got quotes from $800 to $1500 for what took me less than an hour.
I'll be installing a HPWC soon. It's the same amount of work as an outlet.
My cheapest quote $2k. Screw them. Have 14-50 in the back of the house, in the basement. Will use this https://www.amazon.com/gp/aw/d/B079JBWR6W?th=1&psc=1Right now, my thought is to do it myself and then possibly pay an electrician come out and "bless it." We have a hot tub on the back deck that we don't use anymore. It has a dedicated 240/50amp breaker box outside that was run from the inside panel (all installed be an electrician). I can take all of that wiring, run new conduit around the front of the house and into the garage, putting everything back together the way it was before I took it off the hot tub. Then just attach a 14/50 outlet instead of a hot tub.
That's my current plan anyway. I have about two weeks to decide for sure before the car arrives
Chris
Drilled a hole from basement to garage.
