Do you have the MYP or MYLR?I'm happy with my 18x8.5" R241 wheels.
The are painted, so you can see where the paint ends in the bolt mounting holes.
You get what you pay for, they're great for winter so far.
Did you have any issues with load rating on the 19inch?BR14 in 19x9.5 for winter setup.
Just a test fit, then washed and ceramic coated the wheels to be packed away for another three months.
Just tried your code for some RTX spider wheels at wheelwiz and it didn't work. Is it exclusive to the Replica wheels from there?Any questions you guys have with the "replika" wheels? I'm trying to do a video and might be able to talk to wheelwhiz people
Yeah i think its replika and fast wheels onlyJust tried your code for some RTX spider wheels at wheelwiz and it didn't work. Is it exclusive to the Replica wheels from there?
I think the discount code expired? Also do you need to pay customs if you live in the USA?Yeah i think its replika and fast wheels only
ill check and get back to youI think the discount code expired? Also do you need to pay customs if you live in the USA?
Thanks.
worked on my end! Make sure you're not shipping to canda or somethingI think the discount code expired? Also do you need to pay customs if you live in the USA?
Thanks.
I know it's an old thread but do the stock tires fit on these 19x8.5 +40 rims (255/45/19) or else which size did you get?Post 2 pic is 19 X 8.5 +40, they fit fine.
Yes, standard size fits. From tirerack https://www.tirerack.com/tires/tire...eModel=ProContact+RX&partnum=545WR9PCRXXLCSV2I know it's an old thread but do the stock tires fit on these 19x8.5 +40 rims (255/45/19) or else which size did you get?
Thank you, buying these for winter setup. please let me know if anyone has any other feedback or recommendations. I just got the 2023 MYLR with Gemini Wheels and now looking for winter setup (being in Canada, it's a must have for us to reduce some risk from winter driving)Yes, standard size fits. From tirerack https://www.tirerack.com/tires/tire...eModel=ProContact+RX&partnum=545WR9PCRXXLCSV2
- Rim Width Range: 8-9.5"
I have a video on it with a discount too if interested but it's literally plug and play. Same tpms, same tires, same everything.Thank
ksI have a video on it with a discount too if interested but it's literally plug and play. Same tpms, same tires, same everything.
Don't need to get any installation kits either unless you want the black lug nuts.
Try again! I tried both in Canada and USThanks Chris for the tip about the nuts, I am actually leaning towards R263 (19x8.5), same load rating of 1800lb and the cover will hide the silver nuts, 8.5 instead of 9.5 to save rims from curbs.
For some reason the code is not valid regardless of which rims I select. Maybe because I am in Canada, my total shows $1162 (not sure how you say it is $500USD? (I have not see the full video but I am assuming that’s what it says)
ks
Replika R241 Satin Black 19x8.5 +40 5x114.3mm 64.1mm
EVERYDAYCHRIS (-$100.00)
