Wow. Tesla sure is teasing the 40 owners every day. "Don't you want to unlock your battery?" "No, really, you should unlock it"![]()
Wow, no kidding. I figured the 40's would go to 100% and the extra capacity would just be hidden.
Dear fellow TM-S owners. I am as you somewhat troubled by this new 70 kWh battery and the 60 kWh for that matter. I got my S60 back in December 2014 and it seems like I have full access to the 60 kWh. I did a 90 % charge the other day from 1% to 91% and the meter said 54 kWh charged. My 85 kWh friends can not charge 85 kWh!!! My speculation started.
Could any of shed some light on the following:
1. Did anyone ever do a tear down on the 60 kWh battery to see the actual cells and capacity?
2. If there a similar diagram available for the 60 kWh battery:
3. When does a S60 run out of juice? I guess not at precisely 0% which would make people a bit upset maybe. Have the S60 in fact more kWh available than 60 kWh?
The following is purely speculation based on lack of knowledge (above mentioned):
a) What if Tesla at some point in fact placed the same number of cells in each module in the S60 as on the 85 kWh only placing 14 modules instead of 16: 85*14/16 = 74.4 kWh and then software reduced to 60 kWh.
b) if a) is true then the S70 is "just" a S60 with the software limitation removed.
c) Later this year I then will be offered to upgrade my S60 to S70 for xxxx ;-)
/Søren
But anyway. I've physically seen modules from a 60kWh pack. They simply have some number of spaces (can't recall exactly how many off hand) without cells installed.
A range charge (90-100%) only appears to add ~7.7kWh by my calculations also.
/Søren
SQLCPH: Question: When you say meter read 54KWPH. WHich meter are you referring to?
I disgree that Tesla have software restricted the capacity from 70KWh to 60KWh
batteries are too expensive for Telsa to throw margin like that.
Let me correct myself. I went and checked the charging display when range setting is in battery %'s.
SQLCPH: You are correct. In this setting, the charged amount shows in KW's not miles. Also that amount is the DC charge going into the battery (the charge is around 90% of AC Power).
This is new information for me. I am going to go through a charge cycle to see what number I get on my car.
Based on your reporting, it does seem like there is no buffer. 90% == 54KWh then 100% = 60KWh so where is the buffer?
SQLCPH: In any case, how many ideal miles range do you see at 90%? Ideal Miles*0.267 gives KWh number. We can corroborate if it will match 54KWh.
54kWh usable makes sense for the 60 pack. That's 10% anti-brick buffer below 0 miles.
... If they are just adding cells to the original 60 pack, then we should see a heavier car with a corresponding drop in efficiency. But from the new specs on the 70D, it looks like it is retaining near identical efficiency of the S60. This suggests the battery didn't get much heavier.
