Never mind. I just realized.I’m sorry if this is a very dumb question but what is the signature? Is it like a signature on an email or is something entirely different? Thanks!
6 posts are required before you can add a signature and avatar
good to know what's required to add a avatar and sig line. Glad I stumbled on this thread!Hi! How can you add a signature line to your posts? Thanks!
Thanks, I was having the same issue!6 posts are required before you can add a signature and avatar
I realize that this is an old thread with LOTS of spurious posts (post count building) but I am unable to add a signature or update my icon (replace the yellow K).Please hover your mouse to right upper screen above your photo. It would open up a menu with "Signature." Or you can click that photo and it would give you another page with Settings, Personal Details, then below that is Signature.
Good luck!
If you go to the top of the screen where it says your username, left click and a box should open up. About halfway down the box on the right hand side it should say signature and if you click it it will take you to a new window where you can add your signature. I believe you have to make either 5 or 10 posts before the signature option shows up. I had the same issue as you but hopefully my explanation is helpful. Good luck!I realize that this is an old thread with LOTS of spurious posts (post count building) but I am unable to add a signature or update my icon (replace the yellow K).
The instructions talk about hovering over my picture (that I don't have) and there is nothing in Personal Details.
Never mind. Found it! Thanks again.Thanks. That appears to work. Now the same question in regards to the photo on the posts.
Super helpful! Thanks!6 posts are required before you can add a signature and avatar
Thanks Bruce!So for those of you who are making gratuitous posts here just so you can add a signature, consider making real posts with some actual content.
Bruce.
Thanks, this is helpful. However, does anyone know the requirements wrt post count has changed to be eligible for signature. I have about 8 posts and I still can't add signature. TIA6 posts are required before you can add a signature and avatar
Others are still reporting that 6 did the trick?Thanks, this is helpful. However, does anyone know the requirements wrt post count has changed to be eligible for signature. I have about 8 posts and I still can't add signature. TIA
For me I believe it showed after 10 postsOthers are still reporting that 6 did the trick?
I'm more of a lurker.. if the question has already been asked or answered, I don't want to be the person who hasn't tried to look anything up at allSo for those of you who are making gratuitous posts here just so you can add a signature, consider making real posts with some actual content.
Bruce.
