Thank you, yes I agree. All disconnected!Normally, the car will charge the low voltage battery from the main battery. But, if the low voltage battery is depleted, it might not have enough energy to activate the contactors.
To get around this, you can connect a 12V jump box to the jump start terminals to provide enough charge for the car to activate the contactors.
Model 3 Owner's Manual | Tesla
Learn how to properly tow and jump start the vehicle in the unlikely event your vehicle runs out of range.www.tesla.com
You should disconnect your aftermarket equipment until you determine what went wrong.
The BMS in the low voltage battery purposely bricks it if they discharge below a critical voltage. Toss it, you need a new one.It acts like it won't take a charge at all. The car is dead. Can the li-ion batteries be easily damaged?
Cool, thanks! Can I charge these with a 12v lithium charger in a pinch though? (For future reference)The BMS in the low voltage battery purposely bricks it if they discharge below a critical voltage. Toss it, you need a new one.
The battery is not your usual 13V starting battery. It holds less than 7Ah of power and operates at 85% charge, maintained by the big battery. It's a kind of bulletproof filter between armageddon and the world operating at '12v' the way it has its own electronic system bridging it from the big battery.Is there a chance my battery is damaged from a stereo amp?
No. The "dead" battery cuts itself off from the terminals. If the car won't recharge it after you have woken it up then it's toast.Cool, thanks! Can I charge these with a 12v lithium charger in a pinch though? (For future reference)
No, it is not bricked but undervoltage protected. The BMS need to see the correct voltage before it reconnects and charges.The BMS in the low voltage battery purposely bricks it if they discharge below a critical voltage. Toss it, you need a new one.
That seems counter to what is stated in the video - that if the battery drops below a critical voltage where dendrites can form, the BMS essentially permanently disables the battery for safety.No, it is not bricked but undervoltage protected. The BMS need to see the correct voltage before it reconnects and charges.
Yes. The correct voltage must be maintained for safety. That is why the battery shuts down before it gets there. Then the load is removed and with the reset the BMS can go back to work safely.That seems counter to what is stated in the video - that if the battery drops below a critical voltage where dendrites can form, the BMS essentially permanently disables the battery for safety.
Dendrites doesn’t form in this battery.That seems counter to what is stated in the video - that if the battery drops below a critical voltage where dendrites can form, the BMS essentially permanently disables the battery for safety.
