Hi,
Where are the files going? I'd like to export data to excel so I can make graphs looking at energy consumption as a function of speed and outdoor temperature.
Using a Google Pixel3a.
Thanks!
Mattvo, I daresay you've found the answer by now, but for future readers sake...
As P3Orion mentioned above, the files are normally in the the ScanMyTesla folder of what is either called Main Storage or Internal Storage. Using the standard, or a third party file manager, will find them.
However, that said, ScanMyTesla is a little confusing when you press "View Logs", as it seems to invoke whatever app is the default file viewer, which may in turn display a different default folder on start up, making it appear that there are no logs files. You will then have to navigate to the correct folder, described above.
For example in my case, selecting "View Logs", starts up Microsoft OneDrive and that in turn displays "Recent" files by default,
not the ScanMyTesla folder. Thanks to P3Orion, I realised what was happening, but I now have to navigate to the correct folder each time.
