How to tighten knuckle bolts
G26okie
2020 P3D-
Nov 15, 2019
160
112
South Florida
Want to check the torque on the knuckle bolts, but I was curious as to how to tighten them.
The bolt itself has a torx or star female end where the nut goes. Do I need to get a bit in there to hold it and then a wrench on the nut, or can I just get a deep socket on the nut and torque?
Raro
67
67
Los Angeles
If you do it with the car sitting on the ground you won’t need the torx. You might not need it even if you are jacked up. It’s only there so the joint doesn’t spin as the nut goes on for the first time in the factory.
The torque is reacted on the taper once the joint is seated. That little torx won’t hold anywhere near the 130 some odd ft/lb that the nut gets torqued to.
Occhis
253
113
Front Royal, VA
That torx is used most often when removing the ball joint, as it will tend to spin as it loosens especially if the threads have debris that hinders the removal of the nut.
G26okie
2020 P3D-
Nov 15, 2019
160
112
South Florida
Thanks for the replies guys. another forum member who had these loosen just threw a socket on it without issue. I did the same, got them to spec, one on each side was slightly under.
dsgerbc
510
389
Michigan
Are you talking about this bolt?
I did those when I was swapping suspension and then again for upper control arms.
The torx bit was somewhat helpful, but I don't think it was necessary to tighten things up. That bolt only needs 50-60ish Nm. If you can get it snug, tightening further did not make it rotate for me. That's a sample size 1 though.
