I need a 12VDC high-amperage source for my ham radio 2023 MX
Beta V
Author, Dad, Mentor, Technology Critic
Nov 8, 2017
231
163
Redmond, WA USA
I just traded in my 2017 MX. I had my ham radio connected to the trailer brake port under the carpet on the outside wall under the dash. It worked fine. I understand that Tesla no longer uses a 12VDC battery but now uses 16VDC (too high for my radio). Is this trailer-brake 12VDC outlet available on the 2023 MX?
The 12v battery is maintained by 16 volts.
Wow, looks like I should have done a search before entering my thoughts, as it looks like with the change in battery chemistry they have indeed increased charging voltage to a maximum of 16 VDC. I would review voltage input specs on any gear you were considering to install. If the gear can not handle it I would use a DC to DC convertor, but beware as they can induce noise on the DC power. Get one that is sell designed.
Reactions: Beta V
Upvote 0
Yes. The tail for the brake controller is available. But like everything else on the car it will be 16 volts. Some ham gear today has wide range input power, like 8 - 21 volts. But you may need to drop it back with a converter. The biggest challenge for me is where to mount the thing. I thought about sacrificing the cell phone charger deck, I never use it. But then I remember that is the deck for the key card too. For the antenna, I can drill through the spline above the rear hatch. But rig placement is tricky.
Upvote 0
I plan to mount the antenna on the frunk lip. I didn't want to drill any holes and a mag mount
won't work for obvious reasons.
So, 16 VDC. Not cool. I'll look for a converter. The cigarette lighter outlet says it supports 12VDC @ 12-14 Amps. That might be enough as the radio draws about 10 A on the UHF frequencies.
Upvote 0
I tried a lip mount on the rear hatch, but it worked quite poorly. The spline appliquè (looks like glass between the FWD) is plastic and can be easily drilled. You will need a long throw mount to secure it to the metal spline underneath. I found it quite difficult to get the hole exactly centered, so mine was off center a bit. But the antenna worked very well. I left the mount on the car when I traded it in. It had no impact on my trade-in. In fact, it never came up during the trade-in ceremony. I would do the same thing on my 2022, except I don’t know where up front, I could mount the control head.
My radio of choice is a Kenwood TM-V71A, because I already have one, but I have not come up with a method to mount it. Other radios might work better.
Upvote 0
