Canikony
I love how people first claimed the motors were binned.. now they are saying its the inverters... I think we will find out eventually that it is purely software.
I would believe the Tyco Road store. It matches what I know about engineering.
Maybe half the AWDs are unlockable, but I am damn sure *some are not*. If they start offering upgrades, *only some people will have the option*.
Yes, this means some AWD owners got "good bin" motors and others got "so so bin" motors, and they are not telling you which you got. Makes sense. If you unlock the "so so bin" motors they probably overheat.
What’s your source for that info?
We were hearing a month ago that there HAD to be a hardware difference in P versions and that there was no way it was simply a software switch.
What chips are you referring to? The power electronics in an inverter (which determine its maximum output) are either built using discrete transistors or packaged power modules. I'm not an expert in this field, but I've never heard of part binning for those either.
It's BRAKES d@mn it! Although you did get it right the second time!![]()
Sorry my bad, its bin a realy long dey...
My theory is that only the P3D+ is binned due to:
A) fewer production numbers so you can actually DO binning. If both P3D types get "the best" parts, then thats maybe 70-80th percentile. If it's only the P3D+, it's maybe 90th+ which actually gives something worthwhile.
B) P3D+ gets the "performance chassis" and could be segregated by that when being built in Fremont. They would then put the binned motors in anything with that chassis.
From Troy's tracker, roughly 6-8% of orders are P3D's (+ and -) which translates to roughly 6000-8000 vehicles of what they've delivered so far. I think its reasonable for them to have binned both.
Model 3 Order Tracking SpreadsheetOh snap that is interesting, you have a source for that/where is this tracker?
@eric1856I have an interesting data point to add that I may make into a seperate post....
When I received delivery of mine there was a fairly major paint problem. We even talked about switching it for another similar car from the lot if they had one.
One of the employees said, "There are only a few performance models here, so it might be hard to do." Now, I didn't order a P model, just AWD. I chalked it up to tiredness as it was late at night.
A couple days later I'm looking monroney label and found that the main heading says Long Range AWD, but the options are mostly wrong.
My config was AWD, white interior, FSD, 19" wheels . Here is my monroney options rundown:
They also specifically mentioned not being able to swap parts or tires. What is going on in the delivery process that this happens? My vin is 107***.
I wonder...If you are in an accident, and your car is totaled, does the insurance payout reflect the AWD or the P-AWD? What about the Performance add-on?Has it’s benefits though. Cheaper insurance as the insurance is base off the VIN.
I highly doubt there is any "binning" of the electric motors. Motors are relatively simple machines that aren't difficult to assemble to specification, not complex semiconductors with error prone production processes.
