Why place a new "pin" button where the lightning bolt use to be on the map? V10 allowed you to be able to quickly see supercharger locations on the map, and you could zoom in or out on the map as far as you wanted to see superchargers 100's miles down the road. Now when you zoom out just a little, the supercharger locations go away. The pin now adds points of interest to the map as well as supercharger locations. Not necessary at all. I know that you can tap navigation and then see supercharger locations down the road, but the pull down menu must stay down which takes up 1/3 of the screen. Why not have map setting choices under Navigation on the main control panel so that you always have certain things on the map (like supercharger locations).
The new audio display on the UI is unfortunate. You use to be able to go back to your old streaming stations right next to the radio. Very easy to select channels/ Now it is a confusing mess.
Why has Tesla not made a new hardware change so that the left stalk twists for the wipers? Twist it from 0 all the to level 4. Super easy and effective as easy adjustment of the wipers is an important safety issue. In certain weather, you must adjust your wipers often as to prevent damage to the rubber.
Why is the fan now a slider? Is that easier to use while driving? Does the slider allow for the driver to keep their eyes on the road more?
The bottom part of the screen should be fully customizable with the 10-12 features you want (seat heaters, wipers, defrost, etc.)
Does Tesla beta test these UI changes with actual customers that are not employees?
