Vendor Imfamouns Tire Wear Solution!! (2021+ Model S & X) w/ EVPE shims
Looking at the camber in the before and current numbers. They are the same. Toe changed, but not camber. So the shims did not change the camber? I used shims to adjust camber in a Solo Race car. The shims were washers. Just watched the video, and saw initial camber was -2.4, so not sure where your chart is from. -2.4 is way too much for any street car, no wonder the insides wear out. Had some negative camber on my Model 3, and I flipped the tires on the rims and got another 10k out of the tires.
This is before / after the alignment. Both which occurred AFTER the shims were installed
How do these compare to the macsboost adjustment? These look much nicer, but I am curious because the macsboost site does not exactly specify how much camber it reduces, so it is difficult to compare the two options.
Silver = 0.7 degrees of reduction
Red = 1.5 degrees of reduction
I believe our price is more competitive, nicer looking, and our red shims also come with extended grade 10.9 bolts.
Reactions: NJturtlePower
Another happy customer with real world result!
