Imfamouns Tire Wear Solution ( For 2021+ Refresh Model X )
Product Links : https://secretev.com/products/evpe-camber-shim-kit?variant=44070650445986
The issue of tire wear has persisted in Tesla vehicles for several years, with each tire potentially costing up to $600 and having a lifespan of only 5-8k miles.Product Links : https://secretev.com/products/evpe-camber-shim-kit?variant=44070650445986
One of the options on the market is an adjustable camber arm. The part itself would cost between $1k to $1.5k depending on the brand, plus labor, which is another 3-4 hours. It can cost as high as $2500 just to reduce the camber on the rear.
Adjustable camber arms are great for folks who track their cars and need the ability to dial in camber from event to event. However, for most owners who use their cars daily, the ability for adjustment is not as important, as the camber will be set at a certain amount and will remain unchanged for the rest of the ownership.
_________________
At Secret-EV, we are looking for a solution that can permanently provide camber reduction at a reasonable cost.
In response to this challenge, we have developed a precision-engineered shim kit designed to mitigate camber-related issues and extend tire tread longevity.
Crafted from high-grade 6061-T6 alloy, our shims are meticulously machined to seamlessly fit between the camber arm and frame, effectively reducing camber misalignment.
_____________________________________________
Part Cost | Labor | Alighment | Adjustment on camber | Overall total cost (Can vary from place to place) | |
Adjustble Camber Arm | $1000+ | 3-4 hours | Require | Yes | $1800~$2500 |
EVPE Shims Kit | $130 | 1-1.5 hours (DIY friendly) | Require (only toe adjustment needed) | Fixed | $250~$500 |
______________________________________________
For the Model X, We recommened our thickest shims. They are avaliable in both red and stealth grey.
Red Shim & new Stealth Grey Shims : Offers a camber reduction of 1.5 degrees.( Come with extended 10.9 grade carbon steel bolt)
____________
**Alignment is required after the shims is installed**
Recommended Toe
Front Toe: 0.0° to -0.05°
Rear Toe: 0.10° to 0.20°
For any questions, feel free to send us a message or email to [email protected]
