Because that is static, during cornering your car will gain camber. With so little neg camber you're reducing cornering grip.
After I posted that, I did some research and the consensus was between 1 and 2 and slightly more in the rear.
That tends to be how most performance cars are setup.After I posted that, I did some research and the consensus was between 1 and 2 and slightly more in the rear.
So for optimal camber for cornering and tire wear it should be something similar to: Front: +1, Rear +1.5?After I posted that, I did some research and the consensus was between 1 and 2 and slightly more in the rear.
Optimal camber for cornering and tire wear is going to depend on your driving style (how fast you go around corners). Personally, I check tire wear at the end of the summer when I swap to winter tires and adjust alignment if it looks like my tires aren't wearing evenly.So for optimal camber for cornering and tire wear it should be something similar to: Front: +1, Rear +1.5?
This!Optimal camber for cornering and tire wear is going to depend on your driving style (how fast you go around corners). Personally, I check tire wear at the end of the summer when I swap to winter tires and adjust alignment if it looks like my tires aren't wearing evenly.
Do you have a recommend installer in the Chicago area?
@Secret-EV . With the guidelines in this quote and with me stating that I drive 'grocery getter' style 80%-85% of the time but do like to drive spirited (hard cornering and aggressive acceleration) 15%-20% of the time, do you still recommend red/stealth shims or shift to silver recommendation? I know I will lose some cornering grip/improving tire wear by reducing camber but don't want to lose a large % of cornering grip.This!
If you commute on the highways and never push your car in the corners you need far less camber than someone who is attacking backroads on a regular basis. Optimum wear vs alignment settings is very user dependent.
Ok, Good to know. I was doing some spirited driving through some long sweepers a few days ago and the car did not feel as planted as I was expecting. I know this is a big heavy SUV but it just felt like it had more it could give but something in the setup seemed off.Alignment can be pretty complicated based on the car, tire, track conditions, etc.
Generally, if you are talking about cornering ability, front camber will be more important. With the factory front camber at around -1 to -1.2 degrees, the cornering ability is limited. In other words, if you apply more negative camber on the rear with wider rear tires, all you will experience is understeer. (Front loss grip before the rear)
You will see most track alignments run more negative camber on the front to increase cornering traction and a bit less camber on the rear compared to the front to increase forward grip.
We don't believe that going with thicker shims will reduce cornering grip off the factroy setting. In fact, we think it will actually make the car feel more balanced for corner and better straight line performance.
