I ordered my 2023 MYLR with the factory tow hitch. I expected the hitch and wiring to perform like all the other tow vehicles I have had (I was coming from a BMW X3). Nope. Tesla does not supply 12V+ power to pin 4 due to the upgraded Li-ion battery:
This means that a brake controller like the Curt Echo or Prodigy RF Won't work - as they require power from the 7-way. Unfortunately, I have both. So, now I need a third. There are many that attach under the dash, but I don't like how they look or that I need to take them on and off as I need or don't need them. The other issue is that if your trailer uses pin 4 to charge a battery or run anything on your trailer while you are towing, you are out of luck.
I purchased a Redarc Tow-Pro Elite:
I installed it behind the driver side left kick panel (which you need to open to get to the wiring harness):
I used part Tesla Wire Harness Part Number 1072586-00-A with lever wire nut connectors which allow for easy, secure connections and the ability to connect 1 to 2 (my V1 is connected to the same power):
I mounted the controller to a flat metal part of the vehicle behind the kickplate and after it was tested and buttoned up, I didn't want to drill holes, so I used 3M tape to mount the switch to an inconspicious area on the left side of the dash where it is easy to see and reach:
Now, I can keep the controller up and available where it doesn't bother me![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
