Internal Charger Loss
I know this was most likely asked and answered but I can't find it....
When charging with the Mobile Charger (14-50, 10-30, ...) how much charging loss is there. I know that the car tells me how many kW that were added to the battery, but how much is wasted in heat, running the charger and the like.
(I have a M3 AWD 2019)
Thanks....
Thanks....
It’s a Mobile Connector - the charger with the majority of the losses is located in the car. Mobile Connector has extremely low loss as it is just a glorified switch.
Yes it has been measured before.
Good data being gathered currently here by @darth_vad3r:
API charging data
Short answer is there is ~250-350W fixed overhead (TBD the number) and the chargers are about 95% efficient.
In the end this means about the best you can do (at high charge rates) is around 90% efficiency.
Reactions: Rocky_H
Thanks for the help and sorry for mistyped Mobile Connector. A 5%-10% addition to what the car says to what the energy provider bills for is not that bad.
I will look at the thread you gave in more detail.
Thanks
