I happened to notice after install my inverters are sized for a maximum of 10,400 kW but my theoretical panel capacity is 11,340 kW.
It is pretty close but slightly undersized. I've been reading about pro / cons of under or over sizing. What are opinions on this design. It is a design that is in NJ and is facing southwest with little shading on the roof. The two inverters split up half of the 36 panels.
If they chose the next bigger inverter size, it would be able to take 13,200 kW, so somewhat oversized. I should add that I have no plans to add more panels.
Expected production is around 13 kWh per year.
Thoughts?
Thoughts?
