RubySL
New Member
Yes - My iPhone 13 ProMax with an Apple silicone case does not charge in my Tesla. If I remove the case it does charge.Have trouble to connect to Tesla. Any one else?
Not necessarily. I have had the 12 Pro Max for a year and, when it's in the case, it doesn't charge. OUT of the case, it charges fine. It seems to be just 3 mm too high on the coil. It's annoying to have to take it out of the case every time I get in the carto be fair, theres no issues with the iphone 12 pro max..
I tried this on mine and it doesn't work. I also tried it in a friend's Model 3 with the newer interior and it works in his car. I may need a new charging pad.Works with my MagSafe case when upside down
I have a 12 pro max in a case and it charges fine. The case is from Apple and is magsafe compatible. So if you change the case to the right type it will work.Not necessarily. I have had the 12 Pro Max for a year and, when it's in the case, it doesn't charge. OUT of the case, it charges fine. It seems to be just 3 mm too high on the coil. It's annoying to have to take it out of the case every time I get in the car
I may try to find different case (refuse to pay $70 for OEM case since phone because it is too much for 25 cents product). iPhone 13 MAX Pro holding charge for very long time so I don't need to use this for charging just for lay it thereMy 13 Pro Max charges fine on the wireless charging pads (using the OEM silicone MagSafe case and the Mous Limitless 4). Had no issues with my 12 Pro Max either.
