Physicslawyer
My 9/22 MYP is at 80% now and is showing 237 miles. The car has 3k miles on it. It's 31 F outside now.
When the battery is cold Tesla now lowers the range and SOC by 3%. Tesla does this to provide a more accurate range estimate. If you park with 80% SOC you might observe 77% SOC the next A.M. even if Sentry mode is Off.
You should check and see if it is allocated to Standby drain while parked, on the Energy Screen “App.”yup. I noticed that too.
As far as I am aware the blue snowflake is a cold battery indicator. This also means you can expect decreased performance (available power), reduced regenerative braking. Anecdotally after charging I and some other Model Y owners have observed a loss of 3% SOC after the Tesla Model Y has been parked overnight in cold, i.e. 40F or colder temperatures.Clarification requested.
A fixed 3% reduction? As opposed to how it was previously with a variable reduction (blue shaded area of battery icon plus the snowflake icon) based on actual battery temperature? The previous reduction could be anywhere from 1% to almost 10%.
This has little to do with cold weather as far as I can tell. Admittedly, for a Model 3.fter charging I and some other Model Y owners have observed a loss of 3% SOC after the Tesla Model Y has been parked overnight in cold, i.e. 40F or colder temperatures.
Totally fine and a good way to go.I almost never display the estimated range or miles added while charging.
Also will happen at other temperatures.This happens if the temperature drops below 40F overnight, inside the garage.
Yes. You’ll also see the kWh added decrease (in % mode) or miles added decrease. While still plugged in. Since these are net values for a given charging session. See pictures above showing this.The 3% battery SOC drop is immediately apparent (when it happens) as the last SOC changes immediately to 3% less SOC as soon as the Model Y wakes from sleep mode.
Coming back to add a little piece of trivia:However it prevents accurately determining (net) energy added to the vehicle.
