Wattsisname
MY Red/White/Gems
Fan speed 8 seems normal to initially cool down a hot cabin, but excessive to maintain temp. I would suggest using Auto because it will figure out where to blow the air, whether to recirculate or use fresh air, and what the best optimal fan speed is.
What was your mileage at the change? Is the need to change cabin filters a function of time or usage - miles driven that is. Of course, the filter material will degrade with time but I would have thought the filters in a low mileage car would last longer than two years.Have you changed the two cabin air filters since purchasing your Model Y? These filters should be changed at least every 2 years. (I just changed the cabin air filters in my Model Y after two years. The old filters looked clean but I noticed increased air flow from my Model Y HVAC vents after changing the cabin air filters. (My theory (unproven) is that the Tesla Model HVAC system can detect a drop in airflow due to a blocked cabin air filter. After changing the filters it takes some time for the HVAC system to recalibrate the fan speed for the improved airflow.)
Park in the shade whenever possible. (Ceramic tint and sunshade only delay the rise in cabin temperature above 120F while parked in the sun (unless you set Cabin Overheat protection with AC to be On.)
Precondition the Tesla Model Y for 4 or 5 minutes before driving, preferably while plugged in.
Set the HVAC to Auto and your preferred cabin temperature (69F to 72F for my Model Y in warm weather.)
Set the Fan Speed to Medium or High. (In the HVAC Auto setting the HVAC Fan Speed setting (Low/Med/High) functions as a speed limiter not a fixed speed. Fixed fan blower speeds from 1 to 10 only apply when the Climate Control is set to Manual.
Turn on Recirculate Cabin Air so that the AC does not have to work as hard. The Tesla Voice commands are "Recirculate" and "Fresh Air".
The air-con in our seems fine and the cabin is odour free.
But, I stand ready to be corrected/ advised.
![Smiling face with smiling eyes :blush: 😊](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f60a.png)
Then again....... My paranoid tendency wonders If, as you say, your filters were clean, then perhaps the issue was a software nudge at two years to encourage a filter change by affecting a/c performance. ( To far fetched
![Thinking face :thinking: 🤔](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f914.png)
