JRP3
Hyperactive Member
Battery startups to watch in 2013: http://gigaom.com/2013/01/14/13-battery-startups-to-watch-in-2013/
Egads. Another "YC" reference. "YC" seems to be the initials of some character in the "Top Menu" game/puzzle.Somewhat related, jump to the 25 minute mark and Jack Rickard does an extensive discussion of the work being done by Yi Cui, including Lithium Sulfur...
An electrolyte developed by researchers at Oak Ridge National Laboratory could enable lithium-ion batteries that store five to 10 times more energy and are safer than the ones that recently caught fire on Boeing’s 787 Dreamliner.
The solid electrolyte not only makes batteries safer, it could also enable the use of higher energy electrode materials. As a result, while the rate at which these batteries deliver power may be less than today’s lithium-ion batteries, the total amount of energy they can store would be far higher. A much smaller battery could then be used—saving space and weight on airplanes and greatly reducing the cost of electric vehicles.
The work is still at an early stage. So far, the researchers have only made small, half-inch test cells, And the results demonstrating the compatibility with lithium-sulfur batteries are still unpublished.
For car design, “It’s almost as if the properties of steel were improving at a rate of 5 to 8 percent per year,” said Straubel.
The first step was for scientists to demonstrate the technology can store and release power through 10 charges. Now they’re pushing the unit to work over hundreds of cycles, and build a prototype. That would require further improvements in the materials used for the cathodes, anodes and electrolytes, which form the guts of batteries, Narayan said.
“We could see a radical advance if our prototype excites a manufacturer with a compatible technology,” Narayan says. “We’ll have a prototype ready next year, and then with our partners we’ll look at the engineering timeline. Five to 10 years is a reasonable time to commercialization.”
[video=vimeo;51873011]http://vimeo.com/51873011[/video]
Somewhat related, jump to the 25 minute mark and Jack Rickard does an extensive discussion of the work being done by Yi Cui, including Lithium Sulfur. It's about a 45 minute segment because of "Jack time".
Don't forget that's only half of the equation, they are doing something similar on the cathode side with sulfur encapsulated in TiO2. You need both anode and cathode to get the energy density.
You probably could. I don't remember what the electrolyte depletion referred to.Why can't you just scale the cathode larger to accommodate the anode capacity? It would reduce the power density gains to half but there was more that I couldn't hear.
Silicon based anodes for LiB is a hot field with dozens of companies trying to commercialize it right now.
As for electrolyte, usually they use lithium salts with organic solvents. And those solvents decompose as time go by. But that is usual case, do not know what depletion referred to in that particular case.
