If LM do have a military application for it, what is the danger of the technology becoming ITAR restricted, or worse?
I wasn't saying that larger format cells would help with those attributes, just that EV makers would like to "have their cake and eat it too" with easier to package larger cells, that also have improvements in many areas including the ones I mentioned.
Cost reduction is still probably the most important attribute we need improved though. If a pack that gives you 200+ miles costs $20K it will keep decent EVs out of the hands of the mainstream.
Reduced cost of packaging but with much higher cost of cells. Where's the bennefit?Fewer larger cells would certainly be better. Fewer interconnects, simplified battery management, more temperature stability, simpler packaging/faster assembly, all which should lead to reduced costs.
At some point their should be a benefit. We don't really know the costs involved, but potentially one larger cell at x price could be less than 20 smaller cells at y price. At the factory level it doesn't take all that much more to wind up a large cell than a small cell. There is a reason our 12 volt starting batteries aren't made up from 6 individually packaged cells.Reduced cost of packaging but with much higher cost of cells. Where's the bennefit?
Sure, but you cannot just jump there. 12V batteries are produced in houndreds of millions, it is a big market. It can very well be optimal to design and build them in monolithic way.At some point their should be a benefit.
A larger mass changes temperature more slowly, simple as that. True that leaves less surface area for cooling but that doesn't mean it can't be enough. There may also be a more stable chemistry, one that may not necessarily have a lower energy density. Lower internal cell resistance should allow less heat buildup....more temperature stability...? Only if you build larger cells with cooling channels running through them. Otherwise you reduce the surface area to volume ratio. Which may be okay if your chosen cell chemistry is more resistant to the effects of higher average temperatures. But as we all know, cells with this property seem to have lower energy densities.
In 1972, Mercedes built an electrically powered people carrier called the LE 306. Its 31kW (42hp) motor could zip it along at 70km/h (44mph), with a range of 65km (40 miles). A contemporary press release explained that the battery could be “recharged during breaks or replaced using what is known as push-through horizontal-exchange technology”. In other words, a bloke with a pair of pallet-style trolley-jack things could shove the old battery out of the vehicle while winching the new one in, horizontally. “This procedure, which to a large extent can be automated, takes no more than the time needed to fill up a vehicle’s tank,” the release added.
Depew states flatly that Imara has the best li-ion technology on the market. “Our cells are delivering three to four times the cycle life of the best batteries that Sony and Sanyo have on the market,” he claims. Depew says that as many as 10 of the top 16 vehicle companies have come sniffing around Imara’s technology. “We’ve definitely had discussions,” he said.
Imara is ahead of many battery companies in that it already has manufacturing capacity in California, enough to finish a million cells a year, Depew said. It asked for $80 million in federal funding from the so far undistributed $25 billion Advanced Technology Vehicles Manufacturing Loan program to build the capacity to make 30 million cells a year.
