nakedsushi
Call Edison and see if they will recalculate your last bill on the Home & EV Plan so you can compare. If they can't/won't do it, see if you can download your SmartMeter data. From that, I have a spreadsheet that can bin the time periods and calculate the energy charges from the tiers. I don't have the SCE rates in the spreadsheet because I'm in PG&E territory, but it's designed to be easy to modify.
Yep I did call and while they didn't give me exact numbers, they said based on my usage that the most cost-efficient plan is the one I'm on (regular residential). I wish the regular residential plans had an off-peak charge. You'd think SoCal Edison would want to incentivize people to use power off-peak.
You need to change to the Home & Electric Vehicle Plan (TOU-D-TEV) plan. This would give you the same pricing for super off peak even at 2 tier which is the max tier. I use a similar one for PGE which is similar to all you can eat during off hours plan. My bill has only gone up $40 a month from $60 to $100 average now.
Yes, but it looks like the Home & EV Plan's higher rate on-peak would actually make the total bill more, even if I charged super-off-peak (12am-6am).
Maybe I'm just not used to having a high electricity bill? My bill used to be ~$30 a month for the past 3 years...I've been spoiled.
