On the charging screen, below the image of the battery, it should have a bunch of numbers. The 3rd one from the left is Amps. It should say 32/32A when charging. What does yours say? There is also a "Charge Current" selector. Make sure that is as high as it can go.
May also try removing the 14-50 adapter from the charge cable and reseating it. There is a bit of logic in there that tells the car what the max charge rate is.
After that you'll need to make sure you truly have 240V at the plug - the car will charge with only 1 phase but will act like it's plugged into a 120V outlet (which is what yours is doing).
