Eric33432
The dryer unfortunately is not in the garage and is on the floor above. It would have been my first option otherwise. A coworker of mine also uses the splitter plug at the dryer for his Tesla.
Also, i just attached the 30ft 10/3 extension to the first outlet and now the voltage drop is within spec even at 12A. I will make sure to not power on any high wattage equipment while it’s charging and am also going to monitor the receptacle for heat. But this is just a temporary solution, need to figure out something which is more permanent.
Well, that temporary way of charging is probably somewhat safer electrically than plugging into the end of that long circuit with 7 or 8 old outlets that are possibly back stab connected. It might be even a little safer if you can replace that first outlet with a new commercial quality outlet that is wired to the screws.Backstabbing is a newbie (or lazy pro) hack, IMHO. If I were writing the NEC, it would be banned.
Depending on how much you drive, that might be OK, and once in a while you could stop at a SuC if needed. Personally, I love driving our Tessies and would hate to be limited how much I drive. So if you need a little more power, another idea might be to plug a NEMA 5-20 extension cord into a kitchen outlet, or even the bathroom outlet as they are on 20 amp circuits, assuming they are convenient to run the cord to your garage.
If the kitchen or bathroom receptacle is not a 20 amp (NEMA 5-20) receptacle, you could replace one of those receptacles with a NEMA 5-20. You would need to buy the 5-20 adapter from Tesla, and extension cord set up for NEMA 5-20.
(Note that it is ok to wire a 5-15 to a 20 amp circuit, but it is not ok to wire a 5-20 to a 15 amp circuit.)
That would be even better if the panel is close to the garage, but with a rental situation no tenant should be working on the electrical system unless the landlord is involved. And you still have to run a cord from the panel to the garage, unless the panel is in the garage.If the outlet is near the panel, then simply adding a new 240V outlet near the panel with its own breaker would be an easy solution.
