Prediction: High pressure turbopump failure.
As they had apparently not started and were in the fuelling phase, this is unlikely. Let's refrain from the rampant speculation...
Why not? A rocket exploded. It happens. There's already plans in place to deal with it. He has to smooth out some of the edges, but for the most part he's probably going to be twiddling his thumbs, so might as well work on the V8 description.
Why not? A rocket exploded. It happens...
*sugar* happens. Dammit...
The satellite was to be doing this...
Starts at upper stage (again)....
it is my understanding that the static fire test is a full "dress rehearsal" of the launch - you just don't let the rocket go. Then, unload the propellant and safe the rocket after the test is done.Why fuel the upper stage for a pad test?
Could be a tank over-pressurization.Viewing in ultra slow-motion (.25) it seems to be a vertical shaped explosion pattern which "MIGHT" suggest a ruptured seam maybe?
Does make you wonder if they two incidents are related.Elon Musk @elonmusk 12m
"Loss of Falcon vehicle today during propellant fill operation. Originated around upper stage oxygen tank. Cause still unknown. More soon."
I hope it's not the helium tank strut...
How hard would it be for a competitor with billions at stake to employ someone to sabotage a SpaceX launch in an undetectable way?
I wonder if it's possible that it could have been caused by something as mundane as a static discharge during fueling.
As for payload, makes you wonder if they should maybe work on a new, quicker means for attaching payload to a rocket, so it can be attached at the latest possible time before liftoff. Some sort of payload crane/rig with a quick connect that could potentially allow payload to be mounted as late as after fueling and just before liftoff.
Nigh on impossible. And if you were gong to sabotage a rocket, you'd want a blaze of glory waterfalling down into the Atlantic 30 seconds after liftoff, not some ground failure where if spacex wanted, they could save face and manufacture any number of non-booster related causes.
This is a frustrating turn of events for the spacecraft industry. Spacex has been pressuring customers to perform the hot fire while integrated for some time now, in order to save a few days of processing time. The very conservative industry has been very skeptical of the concept, and this is a huge step backward. Progress and risk are always at odds with heritage, and spacex is well known . This will take some time for the industry to recover. But...Its not the end of the world. Rockets fail, causes are identified, corrective actions are implemented. Customers will scrutinize those steps, but generally the collective technical prowess of the industry is sensible enough to set aside their FUD and agree to move forward.
On a personal note, as a spacecraft manufacturer, it was heartbreaking to see the fairing tumble to the ground and explode. As a former floor engineer and test conductor of 'wet' spacecraft moves, its a somber reminder of how much energy is in a fueled spacecraft.![]()
