i have a 2018 100D with MCU2. I bought a LH amp for it, which sounds great but makes a popping noise whenever the system powers up, ie opening the doors. I thought it was a defect with the amp, which was RMA’d and the new one does the same thing. I suspect it has to do with the power saving mode in MCU2, whereas the MCU1 cars had the always connected option, MCU2 doesn’t, so it completely powers stuff down and when it comes back on you get the popping. I wouldn’t get the popping if you started the climate remotely. I’ve actually removed the amp at this point popping was annoying and made the car sound cheap.
I don’t know if anybody else has it installed in a MCU2 car and if you have the same problem or have found a solution. At this point I am considering selling the amp, but wanted get other opinions first.
