at least they should construct a large delivery hub by any of the motorway exits (M1, M4 etc) with waiting area in the first floor and handing over the cars from the covered basement
Sorry, but I don't see the point ... stroll up to "reception", provide ID and be given the keys - probably all of 5 minutes. Not sure what else is needed ... and anything else is just more overhead cost for the site to have to provide and, ultimately, the punter to pay for. Spotty-youths on hand for anyone that has a snag with anything. Its certainly different to dealership, but my experience of dealerships was mixed. Sometimes the handover person was really good / knowledgeable, sometimes they weren't, in which case they were a hindrance.
Last one I got was from a derelict parking lot (Staines) whey they had erected a Tent for "Reception"
If you’re open to changing supplier to Octopus, they will schedule your charge automatically in their 6-hour off peak window (10p/kWh) via the car’s API.
Thanks. I use an API scheduler (TesalFi in my case) to do a number of things, including stopping the charge when Off Peak ends.
I am thinking of charging at home with 3 pin for now and delay the wall connector for a bit, from my calculation 3 pin charges 2.3kw per hour, for standard range plus it takes about 18hrs !
Nothing wrong with that
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
but maybe a couple of things to consider:
Wear and Tear on the UMC (which is similar price to a wall charger)
13AMP ringmain socket not designed for continuous 2.5A draw. Make sure the plug isn't getting hot (if it does try one nearer to the consumer-unit - e.g. an old, frayed socket the previous home owner added to the garage is probably sub-par!!)
If you are going to take it with you "just in case" then that means coiling it up on a wet day
Its less efficient than a wall charger (dunno how much, but might be as much as 10% ... but would take a long time to get the wall charger value back ...)
Wallcharger means that the UMC is available as "backup". UMC-only means no backup if something happens to it.
Electricity Price - UMC is, say, 8 MPH, Wallcharger 25 MPH. Taking advantage of, say, a 4-hour overnight Off Peak will mean that Wallcharger can supply 100-ish miles. For anyone with a daily commute less than 30 miles that's moot.
