Logged into TEG
getakey
2,298
943
95762
I want to check my PWs max charge as I think one of them is down close to the warranty threshhold. I have done this before, but quite a while ago. I logged into the TEG and all I can get is the Summary screen. No where to go to the details on each PW
What am I doing wrong?
After logging in go to <GatewayIP>/api/system_status
Look for "nominal_full_pack_energy". The first instance will be all the powerwalls combined. The remaining instances will be the individual powerwalls.
but that is all there is in the screen shot I posted. Nothing to scroll down to and no links to the individual PWs
To get to the page you screen shot you go to http://<GatewayIP>/
After you log in you need to enter a new URL in your web browser: http://<GatewayIP>/api/system_status
It will output something like this (some web browsers are better at formatting the data):
{"command_source":"Configuration","battery_target_power":-262.25,"battery_target_reactive_power":0,"nominal_full_pack_energy":27279,"nominal_energy_remaining":25679,"max_power_energy_remaining":0,"max_power_energy_to_be_charged":0,"max_charge_power":10000,"max_discharge_power":10000,"max_apparent_power":10000,"instantaneous_max_discharge_power":24000,"instantaneous_max_charge_power":14000,"instantaneous_max_apparent_power":11430,"hardware_capability_charge_power":0,"hardware_capability_discharge_power":0,"grid_services_power":-0,"system_island_state":"SystemGridConnected","available_blocks":2,"available_charger_blocks":0,"battery_blocks":[{"Type":"","PackagePartNumber":"3012170-05-B","PackageSerialNumber":"","disabled_reasons":[],"pinv_state":"PINV_GridFollowing","pinv_grid_state":"Grid_Compliant","nominal_energy_remaining":12784,"nominal_full_pack_energy":13580,"p_out":-130,"q_out":0,"v_out":238.4,"f_out":60.019000000000005,"i_out":2.7,"energy_charged":4141850,"energy_discharged":3610580,"off_grid":false,"vf_mode":false,"wobble_detected":false,"charge_power_clamped":false,"backup_ready":true,"OpSeqState":"Active","version":"452c76cbd7a6f3"},{"Type":"","PackagePartNumber":"3012170-05-B","PackageSerialNumber":"","disabled_reasons":[],"pinv_state":"PINV_GridFollowing","pinv_grid_state":"Grid_Compliant","nominal_energy_remaining":12895,"nominal_full_pack_energy":13699,"p_out":-130,"q_out":20,"v_out":238.3,"f_out":60.019000000000005,"i_out":2.5,"energy_charged":4193480,"energy_discharged":3652190,"off_grid":false,"vf_mode":false,"wobble_detected":false,"charge_power_clamped":false,"backup_ready":true,"OpSeqState":"Active","version":"452c76cbd7a6f3"}],"ffr_power_availability_high":7482.000000000001,"ffr_power_availability_low":3200,"load_charge_constraint":0,"max_sustained_ramp_rate":2500000,"grid_faults":[],"can_reboot":"Yes","smart_inv_delta_p":0,"smart_inv_delta_q":0,"last_toggle_timestamp":"2023-08-18T05:57:44.223209-07:00","solar_real_power_limit":1.7976931348623157e+308,"score":10000,"blocks_controlled":2,"primary":true,"auxiliary_load":0,"all_enable_lines_high":true,"inverter_nominal_usable_power":11600,"expected_energy_remaining":0}
Reactions: Tim-in-CA
thanks
I'll try that today. I do know that when I logged in a year ago or so, I could see the info in the web app directly
ok, this worked. Thanks
One of my PWs is down to 10441 capacity. So that is like 77%? the other two are at 13283. The PWs are 4 years old
thanks
It was never there on the direct tesla page you are referencing on my system (since mine was installed in 2020). to get it, you always had to do something similar to what @yblaser said.
EDIT: I didnt realize it when I posted, but I see I said the same thing @miimura said.
