That makes perfect sense (both theories). If its the first one (which it could be, I dont know), that would imply that
@getakey has had an imbalance in capacity for enough time to generate those numbers, which I would (very politely) ask the tier 1 person to explain to me.
Another thing I might do is to see if all of my powerwalls could provide the stated 5kW output rate. Meaning, If possible, I would try to get my house load high enough to max out powerwall discharge rate and see if that matches what the spec sheet says of 5kW per powerwall. I believe
@getakey has 3 powerwalls, so if possible, I would have the powerwalls set to be able to discharge, then try to drive the home load above 15kW (perhaps by charging a car, turning on AC etc and see if the 3 powerwalls actually output at a 15kW rate or not.
Speaking in general terms, if (for example) one had 2 powerwalls, which means they are supposed to be able to output at 10kW, but they only output at 9.8, one would have something else to discuss with Tesla energy support when contacting them, along with the capacity difference, and usage difference.
