lolachampcar
Just out of curiosity, you may want to pull a rear tire and place the upright on a bit of wood that holds the upright at something close to its normal position. Cycle the air up and down then check the angle of the link to potentiometer arm. Normally you would want this somewhere around 90 degrees so that suspension movement is turned into potentiometer shaft rotation with the best efficiency. When things get out of whack too far, the suspension can move a lot with very little input to the potentiometer shaft making accurate ride height control difficult.
I speak from experience having built suspension lowering modules that "fooled" the suspension control module by offsetting readings from the potentiometers. Links allow you to maintain the correct geometry while the spoofing approach does not. I ran into situations where too much offset hurt the overall system's ability to accurately manage ride height.
New Page 1
New Page 1
