I am assuming that you are trying to open the FWD outside of your garage. When the X was parked in the garage and the FWD openings are limited (due to ceiling or other obstructions), the X notes that GPS location. If you merely drive out to the driveway in relative proximity to the Garage's GPS position, the FWD and overhead sensor will limit their opening as the same as the garage. Of course you can manually over-ride by pulling the internal open switch. However, I would NOT recommend choosing the Option to OPEN FULLY in this location since the GPS position is not sufficiently different than your garage.
To test -- drive the X at least a few houses (1 city block) away, and open the FWD normally. If they open fully, the it is the GPS position of your garage that is limiting their opening. Good luck.
