Can Tesla fix this with a software update?
Phil thinks it's not necessary and if so, I don't know why they keep it on. But we don't really know. It could be used.It is odd Tesla has not limited or /dev/null the kernel logging since it appears they do nothing with it...
I'd have to say that, generally, the overall flash endurance limit has not been improving but instead it is getting worse. I've been a memory test engineer since 1979. I've had some small experience with NAND flash. Over the years of semiconductor process development the amount of storage available in each individual device has essentially expanded by three orders of magnitude (MB -> GB). Some of this is due to the memory cells physically getting smaller and some of it is due to multi-level cell (MLC) storage techniques. That results in the reduction of the number of times (cycles) you can erase and write each cell. There is a design which offers longer endurance than others and that's single level cell (SLC). Most of the flash memories today use one of the multi-level designs as people are usually more interested in being able to store more data in their device or having the lowest cost-per-bit, rather than being concerned about the number of times they can re-write it. SLC designs can typically reach 100,000 cycles while some of the newer MLC designs are rated in hundreds of cycles. Some flash memory manufacturers offer "high endurance" or "dashcam" memories which either use SLC or has a built in memory controller that uses a better wear leveling algorithm or has a more robust error correction system.
@wdolson I was under the impression that car-software logged in a completely different place than the kernel logging.. agree, sending kernel log to anywhere else or shutting it down isn't rocket science.
The high figures might be true for SLC but gets worse with MLC, TLC and QLC.Are you doing failure analysis or counterfeit testing? I write software for a curve tracer system used for both.
When I first did my first flash memory design in the late 80s, the advertised mean time between failures for flash memory was about 1000 writes. They can take a lot more than that today. I think an individual cell is usually rated for at least 100,000 writes.
There have been several torture tests like The SSD Endurance Experiment: They're all dead.I tried to find the stress test of SSD, but couldn't in a quick search. They found the Intel drives had the best error correction and they failed most gracefully when the drive limit approached. Though all drives gave plenty of warning before completely failing.
Neither. At the time I was writing test programs for NAND flash (mid '90s IIRC) it was to do basic functionality checks. I never got too involved with flash; my focus was on SRAM and DRAM. As far as using curve tracers to do failure analysis or counterfeiting checks that was what the QA department would do.Are you doing failure analysis or counterfeit testing?
See these, for example:
Samsung SSD 840: Testing the Endurance of TLC NAND
What is SSD write cycle? - Definition from WhatIs.com (not sure how reputable this is)
The Crucial P1 1TB SSD Review: The Other Consumer QLC SSD (QLC)
The Samsung 860 QVO (1TB, 4TB) SSD Review: First Consumer SATA QLC (QLC)
