Its clearly the wheel, not the caps...You're lucky that these are just hub caps.
Aren't you worried about rust?I've already had to clean up rim rash,very similar. Take 100 grit wet or dry paper then finer paper down to 400 grit or finer. Really did not need paint. Remove the aero covers first.
I read horrible things about these. They will sometime fly off due to sticky loosing its stickiness overtime. Look into alloygotor.Can these be used on the Gemini wheels if you apply them, then put the caps back on?
Rim Savers (only $79 w/ 20% discount)
Does anyone know HOW this is applied?
Or you could do what I do: leave it be and not feel as bad about the next time it happens.I know I can take them to a pro, but is there ANY over the counter product that will cover this minor rash?
Nope, not with this'll alloyAren't you worried about rust?
I was told every time you replace tires or remove the rim they have to be replaced. Just a FYICan these be used on the Gemini wheels if you apply them, then put the caps back on?
Hi! This product not only helps to cover scratches but also protects the wheels during scrapes.Got too close when parallel parking.
View attachment 580655 View attachment 580656
Buy the exact color for even better results. Apollo wheel is Sonic Silver, WPB-8838-3.Get a fine grit sandpaper or sanding block to smooth it out a bit. Then cover with silver automotive wheel touch up paint. Easy to find via google. Should match well!
The mags are made of aluminum they do not rust but might oxidize if he lives in a area that uses salt during the winter it they are in a area without salt the aluminum will stay cleanAren't you worried about rust?
Yes those work, you need to deflate the tire and insert them between the rim and tire, then re inflate the tire.Can these be used on the Gemini wheels if you apply them, then put the caps back on?
