I got a chance to play with the Model 3 over the weekend and I had a couple questions about the sound system. I tested it using a playlist of various songs over an assortment of different genres. On the same road at the same speed, I would listen to several different tracks and the sound level between songs would be totally different. This is through Bluetooth using Apple Music with High Quality Streaming turned on. I also had EQ, Volume Limit, and Sound Check turned off on my iPhone. I turned the audio volume on my iPhone all the way up so the only adjustments I’d make were on the Model 3 itself.
I know audio mastering varies by song, but I’ve never noticed this with any other car or any other headphones (including Bluetooth). Usually I can set the volume at the same level when listening to music and not have to worry about changing the volume with each song - maybe a notch up or down every once in a while, but not having to change it a significant degree with almost every song.
I set all EQ levels on the car to 0, left Balance in the center, and messed around with the immersive sound setting but kept noticing this issue. Has anyone else noticed distinct fluctuations in loudness between songs when streaming over Bluetooth?
In addition, I noticed the bass would vary tremendously between songs. Sometimes it would be incredibly punchy while other times it would be almost nonexistent. Again, I know audio mastering is different with each song, but I've never noticed a difference to this degree. At times I would have to lower the volume because the bass was so high, and other times I would have to raise the volume because I could barely hear any bass. Anyone else notice this as well?
